Hoodie Laptop Sleeve
74,405
186
29
Published
Introduction: Hoodie Laptop Sleeve
Turn and old hooded sweatshirt into a protective laptop sleeve.
First let me say don't be intimidated by the fact that this involves sewing, this is only the 2nd thing I have ever sewn using a machine, and it turned out just fine.
You will need:
- An old Hoodie.
- Scissors
- Something to mark with.
- A sewing machine (or the appropriate hand sewing skills) with the applicable needle and thread for your chosen method.
- A ruler/Strait edge if you don't wanna eyeball it like I did.
- pins.
Step 1: Mark Your Sweat Shirt
Step 1. Layout your sweatshirt as flat as you can (Image One)
Step 2. Lay your laptop about 3 cm (about 1 inch) above the bottom band and try to center it left to right on the pocket. (Image Two)
Step 3. Use chalk, a sharpie, crayons, human blood, or anything that will show up on the fabric to trace out a line leaving about 1.5 cm (about a half inch) padding around the laptop and an extra 1.5 cm at either the top or right side depending on which you would prefer to be the opening. (I used the top, also i just eye balled this as I'm sure will be more than apparent, so you may want to use a ruler for this). The margin will vary vary depending on the thickness of your laptop, just guestimate and you should be ok... the measurements listed are for my laptop which is only about 4 cm thick.
P.S. don't worry to much about marking up the fabric as the edges will be sewn and trimmed before we are done.
Step 2: Cut Up and Pin Your Sweat Shirt
Step 1. Cut along the lines you have just made with a sharp pair of scissors, making sure to go through both the front and back layers. (Image One)
*** Optional. if you will be storing you laptop on its end (vertically). you may want to take this time to sew along one of the curved sides of the pocket. this will give you a long narrow pocket with an opening at the top, so things wont fall out the bottom of the pocket when your done. (Image One note)
Step 3: Pin and Sew the Open Edge.
Step 1. On whichever end you chose to leave open (the side with the extra padding on the border) you will now need to fold back and pin. (Image One).
Step 2. Sew this seam closed. and repeat this on the other layer. (Image Two)
Step 4: Pin and Sew the Remaining Edges.
Step 1. Place the two layers face to face, and Pin the unfinished edges together leaving the top open. (Image One).
Step 2. Sew the along all 3 pined edges about 1 cm in. (Image Two)
Step 5: Trim and Reverse Your New Laptop Sleeve.
Step 1. Trim the excess from the newly sewn edges. (Image One)
Step 2. reverse the "Sleeve" (Image Two)
Step 6: Insert Laptop and Cables
This step is pretty self explanatory just look at the pictures... lol.
Optional... use stencils, paint, buttons/pins, patches, etc. to decorate your new laptop sleeve.
Even more Optional use the the arms of the now chopped up hoodie to make cold weather Ninja Mittens.
Enjoy.
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    29 Comments
    Awesome.. just made one.. Used the sleeve instead for the charger.. made it into a little pouch using the cuff as the top of the pouch. Made it more of triangle shape so the cuff was smaller than the base. Only sewn on 2 sides. Goes great with this and then I won't stretch out the pocket on the front!
    Interesting, though I took the idea and bonded layers of fabric using a tube of clear caulk instead. I find the stiffness that results adds more protection than just a floppy bag.
    This is such a cool idea! I was looking for a DIY for my old hoodie. Specifically a bag to carry a laptop-like device I have(an alphasmart). I look forward to making this.
    I forgot to ask...how should I go about following this process if I have a hoodie with a zipper down the front?
     very cool design. I like the texture
    i found this through a group called ninja tools. why would a ninja need a laptop in the middle of a mission? so he could throw it at someone? seriously people.
     maybe he needed to look something up.
    or email his wife he wants hamburgers for dinner.
    you never know.
    Or look up something on instructables because he left his shuriken at home!
    i think this could be even more handy if you use the sleeves as a shoulder strap!
    now that, my friend, is a clever idea!
    Great idea! I'm goana make one of these for my Mini 9!
    Love it! made my own in about 30 min. great idea, i especially like the pocket!
    Thanks so much for this. I have an old hoodie that i was going to throw away and now i have a use for it. :D
    I like my hoodies too much for this, and i dont have any old ones :(. I might just pop down to primark and get one for like a fiver coz i had a great idea of sewing one end of the pocket up then put a zip on the other end and then voila you have an extra pocket to put mouse and charger in!
    Great way to give old life to an old hoodie! I was wondering though, what type of thread did you use? Something heavy duty I hope? It would be rather unfortunate to go through all the trouble and then have it fall apart at the seams just a few months later. Thanks for sharing!
    wow, this thing has been on Threadbanger, Craftzine, Craftstylish ... If i had known it was gonna be so popular i would have used a nicer hoodie... and maybe measured... lol
    going to make one today !
    I was desperate to make one of these so bad... although I didn't have any sweaters to make this out of, I managed to make one out of a 12" X 18" blank canvas. It worked really well!!! There was no cutting involved what-so-ever after the initial cut. After sewing the edges together it was snug like a book cover and allowed for an even better grip on my laptop. And as a bonus you can draw on the canvas to give it personality or paint it. It's fine the way it is blank. I cut a small hole in the back so I can charge it at the same time. Kudos to the instructable for the idea!!!
    my friend has a purse sort of like this. the difference is whoever made it sewed the sleeves together to make a shoulder strap. i never thought of this possibility. good idea!
