A hoop house is generally defined as a simple greenhouse and is commonly used for season-extension, allowing crops to thrive and be cultivated well after their normal growing season. It is generally constructed using basic materials such as pvc pipe reinforced with rebar for the frame and a plastic sheet to cover the structure.
Step 1: Supplies
First figure out the dimensions of the greenhouse you are constructing. A hoop house can vary in size depending on your needs. The one we are working with in this description is approximately 13' long x 10' wide x 6' tall.
What you will need:
*PVC pipe (in our case we used 3/4" pipe)
* Re-bar
*PVC T-fittings( you may need 2 or 3)
*Zip ties
*Plastic greenhouse liner
*PVC saw
*Measuring tape
*Cement blocks
*Wooden planks(the length and width of your greenhouse)
*Optional: Wood( if you choose to build door frames)
Cyrus says: May 2, 2013. 2:27 PM
Awesome instructible. Would it be better to have a clear plastic for the greenhouse or is the translucent okay? Do they even make a clear liner?
RoBear613 says: Apr 29, 2012. 2:49 PM
I do a lot of "googling" and came across these:
http://www.formufit.com/pvc-4-way-cross/
You can fit the ridge pole to the cross hoops in one piece.
jessyratfink says: Apr 19, 2012. 11:34 AM
Wow! That looks awesome and seems fairly easy to build. :D
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
