Hose clamps are ubiquitous in plumbing, and clamping a hose to a fitting tightly is critical in any plumbing system. Traditional hose clamps work great, but they can be bulky, and they don't work well around irregular shapes. Using stainless steel lockwire (also called safety wire) and a tool called a Clamp Tite, a custom clamp can be fabricated quickly and easily.
Using this pocket-sized tool with lockwire, lots of types of connections can be fabricated, not just pipe clamps. This instructable will illustrate a simple example for fabricating an easy pipe clamp for a rain barrel.
Remove these ads by
Signing Up
Visit Our Store »
Go Pro Today »
But don't buy them on this site, you can find them MUCH cheaper elsewhere.
http://www.aircraftspruce.com/menus/to/safetywiretools.html
I decided to just pay the nice folks to build one for me.
Your mileage may vary, but I've had great success with these clamps on all sorts of surfaces (plastic, rubber, metal, bamboo, etc.). I have not experienced loosening on any clamp I've created with this tool. Please let me know if you have any experiences different from mine!
The right tool for the job, I always say. The trick is figuring out what that tool should be sometimes!
My only negative comment to this Ible has more to do with the use of the tool and less to do with the Ible itself, and could simply be a misunderstanding: According to your instruction, you are using nearly 20 inches of wire to clamp your 1.25 inch hose, and only about 8 inches of it is used for the clamp. The other 12 is wasted?
Mike, at "DC"
Whether it's a small clamp or a very large one, it's still just 2 6-inch pieces cut off, enough to hold fast the ends of the wire to the tool while tightening.
Or, are you referring to threaded rivets? These are also way cool because it permits a threaded fastener to be inserted in a thin surface that simply doesn't have enough surface area to provide much purchase for screw threads. Threaded rivets can be put into a surface "blind," meaning there is no need to have access the back side of the surface. This is great for attachments in sheet metal or other thin material already installed.
Both are frequent solutions of mine when the situation calls for it.
Thanks for the comment!
This is a nice instructable all the same though.
Good work
Dan
I think I just crashed my brain trying to figure out how to use this.
(Don't even wanna go near figuring out how to build this without buying a welder)
If you ever find the time, could you post a short ible or a usage manual?
TWO turns. No more, no less.
When I say ALMOST refers to the aesthetic, no to the effectiveness.
