Introduction: Host Your Website on Raspberry Pi
Raspberry pi is a low cost development board by the raspberry foundation,for this tutorial i am using the distro provided by adafruit that can be found at http://learn.adafruit.com/adafruit-raspberry-pi-educational-linux-distro/occidentalis-v0-dot-2 all you need to do is download the image and use WIN32 disk to burn the image on to the SD card. This tutorial is very different from rest and focuses on hosting a site from raspberry pi and make it accessible ONLINE (from anywhere in the world).
Step 1: Connect Via SSH
Now connect your raspberry pi to home router using a Ethernet cable. the ada-fruit image comes with SSH enabled so you can connect via SSH immediately.
now you should try to open a SSH session via putty to raspberrypi.local or the speccific IP address( if you have ur HDMI connected it should be there on you screen, or go to ur router config page(usually 192.168.0.1) and check for raspberry pi under DHCP). you can log in to the raspberry pi with user name :pi and password :raspberry.
Step 2: Setting Up You Rasberry Pi
once you have a new installation there are a few things you should do to get things going, that includes expanding your root file system to fit the entire memory card and changing the user name and pasword. executing
sudo raspi-config
will take to to the config page where you can configure your PI.
sudo raspi-config
Step 3: Installing Your Server
Now you have to install a server on the raspberry pi, the easiest is the Apache Server (Lighttpd also works if you are looking for something lighter) run the following commands to install Apache, PHP5, PHP5 mod for apache and MYSQL( if you are planning to use a CMS or a database.
sudo apt-get update
sudo apt-get install apache2 php5 libapache2-mod-php5
now you should allow overrides by editing the 000-default file, you can do that using the following comands..
sudo nano /etc/apache2/sites-enabled/000-default
now edit the following lines
change "AllowOverride None" -to "AllowOverride ALL".
now execute
sudo service apache2 restart
to restart apache witht your new settings
now your site should be up and running u can go to /var/ and change the permissions on www, making it writable.
cd /var/
sudo chmod 777 /www
this will enable you to login using WINSCP and upload HTML pages to your new site. open the browser on your PC and point to 192.168.xx.xx (ip address of you raspberry pi) to view the default page.
You can also install and SQL server using the following comands, with a PHP and SQL running on your server u can have a CMs like Drupal running on it.
sudo apt-get install mysql-server mysql-client php5-mysql
sudo apt-get update
now execute
cd /var/
sudo chmod 777 /www
Step 4: Setup Up PORT Triggers
Now you should have your server running, go to raspberrypi.local or the ip address from your browser on your PC and you should see the default apache page.
This means your server is up and running.
Now the problem is there is no way to access this website from the internet (like if your friend in Mexico wants to see the site :-( ).
so go back to your router config page and set the port triger as shown in the picture below. this tells the router if there is someone trying to send an HTTP request via port 80 forward the traffic to the raspberry pi. This make the raspberry pi accessible from the internet.
Step 5: Have Your Domain Name
Now you have a website that can be accessed from online, but most of you (like me) dont have a static IP (its too expensive), which means every 1day or so , your ISP might change your ipaddress(gateway) so you cant always type in the ipaddress and expect to see your website, so solve this we use a no-ip service that gets installed on the raspberry pi. This service runs on the raspberry pi and tells the no-ip server what your IP address is. No-IP gives you a domain name that will point to your last updated IP, all you have to do in make a free account at set and regiter you hostname it will look like (rspi.no-ip.org) you could also go for a premium domain name. once that is done, type in the following commands to install the service....
cd /usr/local/src/
sudo wget http://www.no-ip.com/client/linux/noip-duc-linux.tar.gz
tar xf noip-duc-linux.tar.gz
sudo rm noip-duc-linux.tar.gz
cd noip-2.1.9-1/
sudo make install
after the install is finished, it will automatically start the configuration, enter the username and password of the no-ip.org to finish the installation.
now you have your server set up successfully now all you have to do is make sure it runs every time you start the raspberry pi. there a couple of ways to do this, this i feel is the most easy one.
cd /etc/
sudo nano rc.local
add the following line , in the rc.local file to make noip service run during startup
sudo noip2
ctrl-x to close the file and save the file.
now reboot the PI by the following comand
sudo reboot
cd /usr/local/src/
cd noip-2.1.9-1/
sudo make install
cd /etc/
sudo nano rc.local
sudo noip2
sudo reboot
Step 6: Visit You Website
after setting up the no-ip service, you should be able to access the website hosted on your raspberry pi using the domain name you chose. You can test if the noip service is running by the following command.
sudo noip2 -S
if you see an valid PID, it means you have the service now running.... upload a few pages and hav fun!!
sudo noip2 -S
