3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hot Glue LED Diffusion
Step 5Final thoughts
Final thoughts
So, this was a fun way to blow an hour. I made a pile of interestingly shaped LED bulbs, and in fact I had an idea for my next instructable that will follow soon.
I'm really not sure what I'm going to do with these. I've been making sun jars left and right, so I might see what one of them looks like in the jar, without frosting the glass. I'm also thinking I might get a string of LED christmas lights this winter and make individual bulbs for each light.
It might also be fun to make some sort of an injection mold and make interesting shapes for the bulbs that way. I'm not really sure how that would work, especially the part about making sure the glue doesn't stick to the mold. If anyone has any thoughts on the matter, I'd love to hear them.
Please leave a comment, positive or negative, and also please rate this instructable. I'd really like to know what you all think about this instructable, my writing style, the idea itself, etc. It's hard to tell what people think when you have 2800 views and only 8 comments, like on my first instructable. I'd also like to see pictures of any interesting glue sculptured LEDs you make yourselves.
Most importantly, thanks for looking, and I hope you enjoyed it!
Remember, anyone who posts pictures of their own hot glue diffused LED project in the comments gets a DIY patch!
43 comments
1-40 of 43next »
Aug 27, 2010. 1:48 PMsmiddenkidden says:
what about using resin molds with clear silicone rather than hot glue? i've made quite a few molds for use in my soap making. normally you'd make a resin mold then use that to make a silicone one, so it would be like making silicone molds over and over, each with an led in it. the silicone is going to be sturdier than the hot glue, too. hot glue tends to get brittle over time, and has a tendency to break bond with non porous surfaces when handled much. but, that can be used to your advantage, you can use a nonstick surface to help manipulate the hot glue into the shape you want, rather like when you're working with molten glass. you could also use other techniques used in glass (lampwork) bead making, like making your base shape and using another color of glue, or glue with glitter in it to add patterns of spirals or dots, etc. i'd think you can take loose glitter and sprinkle it on before the glue dries....and there are a lot of different kinds of glitter, from super fine to translucent to shapes. you could do some really fun things using large LEDs and lots of glue...make flame or flower shapes, etc. could be really fun!
Mar 16, 2012. 9:00 AMregistered99 says:
What I did once was buy some of those silicone baking trays, and just pour resin straight into those. You can get some interesting shapes and come out with an easy-to-remove resin LED mold.
Aug 23, 2011. 7:22 AMaspittal says:
I've been trying to think about how to add the finishing touches to a project for my daughter. I googled leds and hot glue and this came up. It is perfect for what I was thinking. Makes my idea so much better now that I've seen it. Thanks for taking the time to write this up!
Dec 2, 2009. 8:50 PMmagiccowy says:
thanks heaps this helped alot =) im making the glowing cube instructable and didnt want to fill it with hot glue
Dec 20, 2009. 10:52 PMmagiccowy says:
alexanders led cube
Nov 22, 2009. 8:56 AMnein166 says:
This is a great Instructable
Have you tried a RGB or multiple LEDs clustered into a BIG bulb?
Jul 7, 2009. 8:18 PMtensiga says:
about the glue not sticking to the mold after months of playing with hot glue i found out it comes of whatever u stick it on pretty easily if u pour some water on it
Sep 11, 2008. 3:00 PMnert says:
"especially the part about making sure the glue doesn't stick to the mold" I was thinking PVA, but the warm temp mike make ituseless. How about a teflon spray like Elmers 'Dry Slide'
Jun 11, 2009. 10:13 AMa.cowen says:
You could use something like vaseline to coat the outside of the mould. Or if it does stick use a hot knife to cut it out, as the glue will melt again? Perhaps.
Jun 6, 2009. 8:06 PMwebsurfer1232 says:
I found this.
Fired up the glue gun.
Made this.
http://i43.tinypic.com/25ow96v.jpg
Jun 1, 2009. 4:44 PMstonechild says:
I was looking for a way to encase LEDs with a glue gun. I want to build an 8 x 8 LED cube. One that I saw had the LEDs encapsulaled with glue and it looked pretty good. Now I know how to do it. Now to look to see if you've reported on molding the glue which I'd like to do. Thanks for a perfect instrcuctable.
Feb 17, 2009. 6:40 AMKaze says:
This is my favorite new instructable! Having the various finished photos at the end is perfect and really shows how cool of an idea this really is. Great length, easy to follow, nice photographs. Keep the guides coming!
Nov 28, 2008. 1:39 AMj0nip says:
brilliant. I am going to make a glowy fire type thing using this. thank you.
Oct 31, 2008. 6:48 PMrobotmastern says:
you could try exparamenting with lost wax casting ( im not shure of the melting points of glue vs. wax but aslong as wax is less it will work) this procces is not reproducable however it can make more elaborate designs
Oct 29, 2008. 8:16 AMMaxence says:
Nice project, I love it. Just a question: I don't have a hot glue gun, so, would it work with wax? I used to drop melted wax in a glass of water when I was younger, and it made pretty cool shapes, so, that reminded me of this when I saw the project and made me wonder if this would do it too.
Oct 3, 2008. 7:41 PMcapnmckay says:
Now, I may just be being naive, but if the LED's get really hot(and I don't know if they do or not, never having worked with LED's) Won't the glue melt?
Sep 25, 2008. 5:44 AMmarianok says:
Great idea, thanks for sharing it
Sep 16, 2008. 1:35 AMAureliano says:
I really enjoyed your instructable and the style of writing! Very good humor :)
Sep 15, 2008. 10:23 PMT2000 says:
I've been looking for this kind of stuff for my recent project.Thanks
Sep 11, 2008. 10:43 AMenlighted says:
you can get interesting effects with other types of glue sticks, too - they come in many colors, and some even have glitter embedded in them.
Sep 11, 2008. 8:14 PMenlighted says:
oh, you would not believe the variety available online!
for example, http://www.glu-stix.com
Sep 11, 2008. 7:32 PMDorilae says:
I love Love LOVE them! I wanna make LED stuff... I need some motivation.
Sep 11, 2008. 6:00 PMandregiant says:
I had tried with playdough...(covering up the bulb) for my photography effects..too!, but LED beam is so.. useful for acting like a studio light for miniature shoot..
Sep 10, 2008. 12:42 PMfastboy says:
very nice idea! I love instructables like this, those light bulb moments (or LED) where you really start to see things in a different light. Look froward to seeing some more enlightening ideas. I'm so sorry
Sep 11, 2008. 1:21 PMnoahh says:
Ugh. Wow. Its going to take some time to recover from that one.
1-40 of 43next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
306
Author:depotdevoid(depotdevoid on Facebook!)
Like me on Facebook, my poor, fragile ego needs a boost! I post updates about my current projects, and the occasional sneak peak at upcoming instructables! ...
more »
