3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hot Glue USB Flash Drive
Take a Standard USB Flashdrive, and cover it in hot glue for a unique clear case.
Step 1Aquire a USB Flashdrive
You need to buy a flashdrive that is not retractable. These kind have move-able parts, and just make it harder. Any kind of any capacity will work. The final size is usually very close to the original.
42 comments
1-40 of 42next »
May 16, 2012. 6:58 PMacabrera7 says:
What about Baking paper?
May 17, 2012. 9:35 AMacabrera7 says:
ok i'll try. I was just wondering whether parchmet paper is the same as baking paper...
If parchment paper is Oven proof, such as for cooking, then baking paper will work too. as the baking has the same effect.
May 16, 2012. 6:48 PMacabrera7 says:
THIS IS PERFECT!!!!! EXACTLY what i need from those crappy cases, which they don't exactly protect them, because the hub is more exposed make it easier to bend...
AND THIS METHOD WILL STABILISE THE BENT USB PROBLEM!!!! YAY!!!
Jul 12, 2011. 11:02 AMKwartzKitten says:
Thanks for the instructable! This was just what I needed to jazz up an old flash drive. I even took some wire and put a loop in the end of the glue so that I can attach it to a keychain or something so I won't loose it! Because that's a problem with me...
Nov 14, 2010. 10:36 AMBRUL says:
Why not using Aluminum Foil or Wax Paper?
May 31, 2011. 7:48 AMdexdude97 says:
Hey! If you wanted, you could paint it what ever color you want!
Feb 26, 2011. 11:54 PMson of s8an says:
Because the glue will stick to it
Jul 12, 2011. 11:01 AMKwartzKitten says:
You may need several layers for a cheap craft glue, though. Know this from experience.
May 31, 2011. 7:23 AMdexdude97 says:
You could also just use scissors to shape it the way you want.
Nov 14, 2010. 10:31 AMBRUL says:
I have exactly the same usb flash drive :)
I'm not sure I'll give it a try, it's kind of undoable XD
Jun 23, 2009. 9:02 AMbillneu says:
i textured mine with the parchment paper
Oct 25, 2010. 1:56 AMimkwl12345 says:
ah yes i see...... no look i really dont.
Jul 22, 2010. 2:52 PMturbotonic27 says:
cool
Jul 9, 2010. 11:23 PMfireruler12 says:
how would you make a cap for it?
Jul 1, 2010. 8:27 PMmisteravocado5 says:
Is there any chance of this shorting anything out?
Jul 1, 2010. 9:12 PMmisteravocado5 says:
Haha I know, I was worried that it might melt something important.
Jul 2, 2010. 7:22 AMmisteravocado5 says:
Cool. Thanks.
Jan 5, 2009. 7:16 AMstephenniall says:
Good instructable one problem i have spottted is on some flash drives the LED (Light Emitting Diode) Gets very hot and melts the glue
Dec 28, 2009. 6:24 AMknektek says:
thats probably because the led is shorted out
Dec 28, 2009. 9:13 AMstephenniall says:
its a posibility but i doubt it I used the led from a old torch i had So it was a ultra or super bright and got a bit warm .!
I scrapped the hot glue idea and i use epoxy now its alot stronger its water proof etc
Jun 18, 2010. 8:58 PMsanty22 says:
Yeah... probably was a 3 volt torch aganist the 5 volts the usb gives it, needs a resistor.
Jan 6, 2009. 7:18 PMPadlock says:
LEDs don't get that hot (Infact they barely get warm.)... Unless there like the super bright 1W+ ones...
Jun 30, 2010. 11:20 AMjunits15 says:
they can get very hot if they are overpowered
May 22, 2010. 1:16 AMBraisedDuck says:
the hot glue will affect the circuit board. and even if it doesn't, the heat given off by the circuit board will cause d glue 2 melt. other then that, cool
Dec 28, 2009. 9:01 AMblizatrex says:
this is great i have an old ugly flash drive sitting that this will give it a better look;)
Aug 31, 2009. 10:30 AMTrainguyxx says:
wow that amazng! i didnt even know you can do that! i thought it would metl or something similar to that
Aug 29, 2009. 3:52 PMnosebleedXD says:
how come your glue is so clear
Feb 1, 2009. 12:42 PMboyrock375 says:
once my hot glue molding instructable gets posted check it out with this one then you can make usb drives with custom made shapes
Jan 6, 2009. 7:17 PMPadlock says:
I would be careful before doing this to your new 16 gb drive, as heat can sometimes damage IC's. As well as static electricity.
Jan 6, 2009. 3:01 PMlowercase says:
LOL Funny! a very minimalistic tribute to our best friend: The Hot Glue!
Jan 5, 2009. 12:55 PMDoctor What says:
This is amazing! I wonder, could I add color somehow? Green goo usb flash drive?
Jan 6, 2009. 1:03 PMexplosivemaker says:
....I forgot which instructable it was in, but in the project they used colored glue sticks......I thought that was pretty neat as I haven't seen them anywhere......they must add the color when they are melting the stuff down and cooking it.....
1-40 of 42next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:whosdadog
