3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hot Knife for Plastic Cutting!
Probably, the EASIEST Instructable you'll ever see to make the most useful tool a DIYer could ever wish for! Sometimes "simple" is the answer....
Step 1Get a new soldering tip!
Then take a hammer to the end of it until it's nice and flat.
18 comments
Sep 5, 2010. 9:49 PMguitar-is-awesome says:
is this safe? i need to cut thru a sheet of plastic thats pretty thick and think this might be a solution!
Dec 17, 2010. 10:20 PMxeniczone says:
You should wear a respirator, safety googles, do it outside, and keep a bucket of water near by should the plastic catch fire. The reason for this, is the plastic my let of fumes or smoke that will be toxic.
This is ideal for places that a Dermel can't reach or can't cut precisely otherwise you should be using a Dremel.
Dec 5, 2010. 6:04 PMexabopper says:
This is just about the greatest thing in Instructables, but I had trouble making it - hitting the tip with a hammer just caused it to shatter, not flatten. I would use a grinder to harrow the tip down instead of hammering, especially with a cheap iron.
Sep 1, 2010. 6:25 AManthonyyy0 says:
would this be an appropriote tool to cut a design on the side of my wii? (after i remove the case of course)
Dec 5, 2010. 2:45 PMmman1506 says:
use a dremel instead it will be much cleaner
Jun 15, 2010. 1:34 PMAZombieHippie says:
hey thanks for the idea i'll include your idea and give you credit in my next instructable! :)
Aug 14, 2009. 1:21 PMwoodvale035 says:
good idea i have done this on an old soldering iron so i could cut and seal nylon type rope all in one go. it was a pain when cutting rope for use on the boat so i made a blade like yours, now i have plastic cutter in my tool box without doing anything...he he .
it does stink a bit tho..
Jan 18, 2008. 1:18 PMthoraxe says:
Nice Hammer. I am doing blacksmithing, and a hammer like that would be nice. I am currently using your standard run-of-the-mill claw hammer, which is too round and gives me an uneven bevel when I forge blades. I've been thinking of making my own hammer, but i never got around too it.
Feb 26, 2009. 4:30 AMtrf says:
bro if ur gonna forge metals do yourself a favor and go buy a 3 lb sledge i paid $10 you can get them for $10-$20 and its really worth it. Large flat head (yes less dents and rounded areas) and also the weight flattens metal alot quicker!
Feb 18, 2008. 1:10 PMBigNateMI says:
When I started blacksmithing, I just used a cheap cross peen hammer like the one shown here. I removed the machined finish from the face with an angle grinder and a flap sanding wheel. I also blunted the peen somewhat with the grinder, then polished it with the flap sander. It cost about $3, but I already had the grinder.
Oct 6, 2007. 9:55 AM!Andrew_Modder! says:
:-\ when i cut plastic, i just blow torch a crappy pocket knifes blade, then cut the stuff. or take a razor blade and make the tip red hot, then cut.
Aug 6, 2008. 4:41 PMpyro13 says:
Same here,
Oct 6, 2007. 11:42 AMMr. Rig It says:
This is a good idea. You are right sometimes simple is the answer.
Check out my circle ible The circle
Hopefully it will give you even more ideas.
I will keep this one in mind.
Oct 6, 2007. 9:32 AMSpectrace says:
did you try using a chisel tip ? would have been easier to hammer that down than a point tip. and if you can find a thin one, no hammering needed.
Oct 6, 2007. 4:18 AMHandsome-Ryan says:
Nice.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
110
Author:babblin5
