Step 4Preparing the hot plate
Cut the USB wire and pass it through the hole you made previously in the base.
Strip the USB cable and locate the black and red weirs (black wire = ground, Red wire = +5V). You can cut out the white and green data weirs for more space.
Now connect the black wire to the ground pins and the red wire to voltage pins.
The best way to attach the weirs to the pins of the CPU is to cut the wires without striping them and then slide the pins inside.
Finally, you have to attach the CPU to the grill by Epoxy
Enjoy.
http://www.intel.com/support/processors/pentium4/sb/CS-029963.htm
can i use an old CPU, like 368 one or 486
How about a piece of pcb (from an old hard drive or mb) cut in the size of the box, with a square hole in the middle for the cpu? It could be sealed with epoxy or even hot glue since the pcb of the cpu does not get that hot ;)
Soldering even a good chip should cause no damage, though running it as a heater will eat up its thermal budget faster and will make it useless for anything else eventually.
Olly :P
All the CPUs I've ever have I have set to auto shut down at 65c, and I don't think I have ever had a computer shut down because of heat.
Not even ram runs at 1.5v any more (well some does, but it's not common)
A full desktop lower power cpu runs at 3.65v usually. People who overclock sometimes get it up to, if not over 4v. My CPU runs at 3.8v and with just air cooling doesn't get over 50c.
Please sir, this is the kind of thing that ruins instructables.
Please don't mislead people that don't know the difference.
Electrical solder melts under 200c btw.
Though i don't know about servers I'd assume the same.
- they have a decent (and noisy) passive ventilation system
- it's more stable
- it's much less power (the power dissipated increases as cube of temperature in silicon, if I'm not mistaken) and every watt counts in an enterprise-sized DC.
I know by heating this above>200C you may desolder the board. But would a variable resistor be enough to change the temperature here?
CPU's work with low voltage. Older ones (upto Pentium 3) requires about 2volts. But, the newer ones (Core2's) require just about 1.7volts or even less.
And, there are special IC's that will provide with the proper voltage from the +12V supply...!
Bye,
PRAVARDHAN
this is why some usb cables are much thinner than others because they can handle only a small current, after all have you ever seen an external usb powered hard drive with a thin usb lead? and that is why they usually have two usb plugs on larger drives because of the extra current required!
btw cool Instructable I might do that one day I always wondered what I would do with some old chips I have lying around!
