Hot Pocket Snood
2,807
73
10
Posted in CraftSewing
Introduction: Hot Pocket Snood
About: I love making stuff!
Well, this was an experiment…I was looking for a feasible way of keeping the neck and chin areas warm without having to resort to looking like The Winter Soldier. “So,” I thought, “what about a snood filled with heat packs?” And that’s what I did…
What I used:
Scrap overcoat fabric
Medium weight fleece blanket
Sewing machine
Hand sewing needles
Thread
Three buttons
Hand warmers/Heat wraps
Step 1: Angles...
The shape of my snood was determined, to an extent, by the size and shape of the scrap of fabric I was using; but the things you need to consider are length and depth. You will need it to be long enough to fit around the neck with room to ‘breathe’, and deep enough to fit the heat packs in comfortably.
I started with a basic rectangle of scrap fabric, then cut one end at an approximated 45 degree angle. I then lay this piece on top of the fleece blanket and cut around it to create the first lining piece. Next, I folded the slanted edge of the lining piece to create the (basic rectangle) pattern for the next two lining pieces. As before, I lay the cut piece on top of the fabric, and cut around it. The reason why the rectangles have to be shorter will become clearer as the project goes along…
Step 2: Old Sew and Sew...
So now we have four pieces of fabric. This is where we make our first visit to the sewing machine. Pin the two angled pieces of fabric together, right sides facing ensuring that you leave a turning hole large enough to fit your hand in. Sew the pieces together. Trim any excess seam allowance, and clip the corners to make turning easier. Repeat the process with the two shorter rectangles.
Step 3: Pressing Matters...
Turn both pieces right side out, and poke out the corners with a point turner, or the blunt end of a pencil. Give them a good press to make the edges crisp. Now, normally in a project like this, the next step would be to top stitch both of the pieces, closing the turning hole in the process. However, I wanted to keep the edges quite soft as the top fabric was quite sturdy anyway. If you are using a lighter top fabric, machine stitching will help the snood to hold it’s shape. If, like me, you’re using a more heavyweight fabric, here is where the hand sewing needles make their first appearance.
Step 4: There's a Ladder in It...
Anyone who has seen some of my previous Instructables will know that I am IN LOVE with ladder stitch. It’s really easy to master, and is a great way of joining two pieces of fabric without the stitches being visible. So, we’ll be using this to close the turning hole, and for joining the two halves of the snood together.
Step 5: Make Your Mark(s)
With the turning holes (invisibly!) sewn shut, it’s time to head back to the machine and create some button holes. I chose to have three button holes, simply because I had three identical buttons on hand, (but the final choice is yours!) Mark out, on the top fabric, where you would like the buttonholes to sit and out buttonhole foot on your machine and go for it! If you don’t have a buttonhole foot, this excellent tutorial will help: http://www.heytherethreads.com/how-to-sew-a-butto...
Use a seam ripper or tiny scissors to cut the buttonhole open.
Step 6: Up the Ladder (again!)
Now we’re ready to sew the pieces together - yay!
If you’re hand sewing (like me) say hello, once again, to the fabulous ladder stitch! The general rule I have for hand sewing larger pieces is to do things in chunks, so I sewed the bottom together first, then worked along the sides. You will probably find that you won’t need to use many pins once the bottom edges are secured, as your non dominant hand will be able to keep things in place.
If you’re machine sewing, pin the pieces with the right sides together. Sew along the two long sides and the bottom (all the the straight edges). Turn right side out and press if needed.
You probably now have something that resembles a very long purse…
Almost done!
Step 7: Fin...
Back to those buttonholes… Fold the snood over on itself as you would if you were wearing it (it may be helpful to put it around your neck and have a look in the mirror) and mark where you want the buttons to be placed. I chose a small amount of overlap so that the snood would sit loosely and not place too much heat on the neck. Sew the buttons in place, pop a couple of heat packs into the pocket, button it up and head to the ice rink! Or just snuggle up on the sofa…
  • Trash to Treasure
    Trash to Treasure
  • Spotless Contest
    Spotless Contest
  • Pocket-Sized Contest
10 Comments
I'm going to try this for my Mom, she's always cold too, but I think I may add a "skirt" around 3/4 of the bottom so it'll keep her shoulders warm. BTW your Sister has an amazing smile. Great project!
What a great idea!! I just wanted to say, your screen name caught my eye and I laughed for about 5 minutes over Ponchos for Chickens...hahah! :)
I’m glad you like the project, but I’m even more glad that my username made you laugh! It’s all thanks to the wonderful mind of April Winchell: http://www.amazon.co.uk/Regretsy-Where-DIY-Meets-WTF/dp/0345523180 The ‘chicken poncho’ entry made me laugh until I cried :-D
I like the toggles you chose for buttons. The project is well done, hope to see more :)
I really like your 'ible; the way you wrote it and the project you made. I have favorited it as I'm thinking this is a great project for a gift. Under 3 hours to make would you say...?
I think it could be done in under three hours, particularly if the whole thing is made on the machine. I, personally, am a really slow hand sewer - and I remember that it took me about 45 mins to sew one of the long sides together (I was watching TV at the time, which probably didn’t help…) So, I think it depends on the process, and the number of external distractions (!) Hope that helps! Really glad you liked it, though - I was a bit concerned that my instructions were a bit muddled :-)
This is excellent a looks super toasty!
My only real question is, why would anyone NOT want to look like the Winter Soldier? C'mon, that dude was a badass. ;)
LOL! It’s true, he was totally badass; but if I tried to rock that style I’d just look like a crazy woman!
Makes senseXD
Very classy! I never thought of adding heat packs, but that's a great idea!
