3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hot Process Liquid Soapmaking
This is how I make liquid soap, using all the natural oils and no surfactants. This results in a very mild, gently cleansing soap. I suggest you read "Making Natural Liquid Soaps" by Catherine Faillor, for more details and for beginner recipes.
With my process, there's no alcohol to add, no rigged up double boilers, and no bungee cords and plastic to tie to your pot. It literally cooks in the oven!
Edited on 7/22/10 to add:
Not having a recipe in this instructable seems to be a big problem for a lot of people, so I have decided to add one.  This is the recipe I used in this instructable:
24oz soft oil of choice (I use Soybean oil)
21oz coconut oil
3oz Cocoa Butter
12oz Lye
36oz distilled water (to dissolve the lye)
To neutralize: 3oz Borax + 6oz water heated until borax dissolves, then add to your soap
To dilute your soap: depends on how thick or concentrated you want your soap.
Here is link to some free recipes: http://www.snowdriftfarm.com/form_liquidsoaprecipes.html
This instructable is only meant to serve as a 'picture guide' with basic instruction. It is written under the impression that the reader has some experience with soapmaking, and is looking to explore hot process liquid soapmaking. Please observe all the usual soapmaking precautions!
Check out my blog at http://jesplayin.blogspot.com
Here is a very basic list of what you will need.
Stainless Steel Pot
Stainless Steel Utensils (Very important, Lye will eat any other metal, and heat will melt plastic.
A very accurate Scale that will measure up to the size of your batch
Candy Thermometer
Gloves
Mask
An assortment of bowls, and spatulas
Your oils
Distilled water (very important, tap water will keep your soap from forming. Not sure what spring water will do, I've never tried it.)
Your lye (Potassium Hydroxide, KOH, Caustic Potash)
Fragrance Oil.
Step 1Weigh Your Ingredients
Make sure you are as accurate as possible. Usually there's a slighly higher lye amount used in liquid soaps than bar soaps, in order to make sure that the fats are completely neutralized. This excess lye will be neutralized later.
I make my liquid soap in an electric oven, set at 250 degrees fahrenheit. Your mileage may vary.
Set your oven to this temp when you first start weighing your ingredients, so your oven will be ready when you are.
It's usually better to weigh your lye and water first to allow some cooling time for the lye, as it takes the lye longer than the oils to cool. Remember, ADD YOUR LYE TO THE WATER, NOT THE WATER TO THE LYE, unless you like explosions in your kitchen.
Melt your oils in the big pot you will mix in, then add the lye water mixture, and commence to mixing!
29 comments
Jul 30, 2010. 7:49 AMombraman says:
Very cool soapmaking tutorial.........what you said is true there is sooo much info on the web for bar soaps but almost nothing on liquid soap Thank you very much
Jul 12, 2010. 3:26 PMjohngalt929 says:
I know this is an old thread, but please know that recipes cannot be copyrighted. The description of HOW to make a recipe can be, but the basic ingredients cannot. As a courtesy, I would credit the source, but don't worry about copyright...you're just sharing a list of ingredients and measurements, nothing that is protected by copyright law...it's even questionable that the process to make soap could ever be protected (processes would have be a patent protection, not copyright, by the way) So share away in the future, and just be nice by saying where you found the information originally! from http://www.washingtonpost.com/wp-dyn/content/article/2006/01/03/AR2006010300316.html "Copyright law specifies that "substantial literary expression in the form of an explanation or directions," such as a cookbook, can be copyrighted but that a mere list of ingredients cannot receive that protection." In that regards, here's a recipe for liquid soap I found online! 16.5 oz. Sunflower Oil 7 oz. Coconut Oil 5.5 oz. Potassium Hydroxide KOH 16.5 oz. Distilled Water for the Lye Mixture 40 oz. Distilled Water to dilute the soap paste Either 2 oz. of boric acid or 3 oz. of borax mixed into 10 or 6 oz. of water Approx. 3 oz. Fragrance or Essential oil, as desired Soap dye or colorant, if desired Source: http://candleandsoap.about.com/od/liquidsoap/ss/basicliquidsoap.htm
Sep 6, 2009. 1:57 PMLunarCrystal says:
You make a point to say that the lye needs to cool down, but how much? What temperature? What temp should the oil be when you add the lye? Isn't that important? I'm so confused, and I'm starting to get mega-discouraged with liquid soapmaking. This would be my fourth time.... *sigh*
Sep 6, 2009. 3:31 PMLunarCrystal says:
Okay...
I've added my lye water to my oil. Following this method:
http://www.youtube.com/watch?v=eJZ_eL4ponk
And instead of a double boiler, I'm using a crock pot (propane is expensive where I live...)
My mixture is not thickening.... How long should I be mixing for? I've been at it about 15 minutes, and it's still quite watery....
Lye and oil added together at the aforementioned temperatures.
Sep 6, 2009. 3:07 PMLunarCrystal says:
Oh, you're so sweet! I'm doing this as I type, letting my lye cool down to the degree you said. Thanks so much for answering my question so quickly! This project has been vexing me for a week and a half now!! *cries* Heck, thanks for just answering my question period!! Five different sources, and not one answer until yours! <3
Feb 3, 2009. 11:13 AManomdebus says:
If a person found it best to keep the soap in the condensed state, would it be best to neutralize the excess lye or not? Which do you think would keep longer? For example, I would only need a relatively small amount diluted, but it would be easier to do more at once.. My intuition says to not neutralize it to keep it less hospitable to nasties. Thanks
Feb 3, 2009. 1:41 PManomdebus says:
Thanks for the reply. A couple more thoughts.. One solution I was thinking about was using mason jars and either vacuum sealing or using a hot water bath to preserve it. If vacuum sealing, it would probably be best to neutralize as the fumes may deteriorate the sealer. If the oxygen is the problem, I would think the undiluted material would have less oxygen than the water it would be diluted with. Either way would probably be helped with the antioxidant idea.. Thanks!
Oct 9, 2008. 7:25 AMAzureEyes says:
good instructable, i was wondering where do you get lye? Also for the borax can this be found in the detergent aisle? (99 Mule something?)
Aug 2, 2008. 9:44 PMSeattlejo says:
I was all good until the end when you said "check your book for ratios" This would be more helpful with a sample recipe.
Aug 3, 2008. 9:42 AMSeattlejo says:
Thanks for the link, I've got Catherine Failors book as well actually. i just think the tutorial would be better with a basic soap recipe included. But then ready the other comments, i now realize you weren't trying to teach soapmaking, just providing a pictorial of a new process.
Aug 1, 2008. 3:16 PMCoherent says:
Very cool soapmaking tutorial! I'll have to try this soon!
Jul 30, 2008. 5:48 PMUltraMagnus says:
heh, funny this should come up on the front page the day I think about trying this.... how would you modify this to make solid soap? also, you don't mention any figures for the ingredients....
Aug 1, 2008. 1:43 AMUltraMagnus says:
I see, my apologies, i posted this rather late at night. I will take a look at that website, thank you.
Jul 31, 2008. 3:51 PMausisit says:
Hi this put a new perspective on the way I have been making liquid soap & hard soaps since 1985. I'm not sure if your way is easier will test it soon.
In relation to 2 issues regards the caustic or lye it will absorb into the oil more over time and with stirring causing it to as you say neutralize. 2 Potassium Hydroxide will only make true liquid soap not the borax.
Borax is alkaline 1 or 2 ph steps down from caustic. If you were to neutralize the rest of the lye use citric acid therefor bringing the ph down but use to much or to early and you end up with a box of nice smelling separated liquid NOT SOAP. I use only say 20 millilitres of 100% citric per kilogram of soap MAXIMUM to reduce the ph that is when I need to.
For bumpus check out my 23 year old tried & tested soap recipe this tried & tested soap recipe is what I use each time for making hard soaps just adjusting my other ingredients.
The last recipe I added Honey & cold tea instead of some of the water, the one prior to that I added a cup of skim milk powder to make a dove like soap.
Hope this helps
Regards
TJ
From
ausis.info Australian solutions
Aug 1, 2008. 12:25 AMausisit says:
Firstly you did a great job on your instructable. Sorry I was a bit straight forward before I was just trying to help out I was not meaning to sounds as though I was picking or anything. To clarify I only use DPG sometimes at a rate of 1 ml per kilo of soap mainly when I use lavender oil as a fragrance as it helps the trace stay in suspension. Lavender tends to cause the soap to separate otherwise. With the borax I read somewhere it is supposed to help reduce the build up of soap scum on the bath and showers. I personally do not use it normally as I use soft water therefor less calcium carbonate. Sorry again for any mis understanding. Just trying to be helpful.
Jul 29, 2008. 8:53 PMosgeld says:
so does the continued cooking neutralize the rest of the lye?
Jul 29, 2008. 9:00 AMbytowneboy says:
I thought it was really well done.
Jul 29, 2008. 8:10 AMbumpus says:
Awesome!, This is basically what we did in science class last year, but the soap we made was solid... Perhaps an instructable on that next time? :D
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:yetunguez
