3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hot Rock Kalua Pig
Hot Rock Kalua Pig
In Hawaii they cook whole hogs underground with hot rocks and banana leaves. It's called Kalua Pig and it is Amazing. I set out to replicate this delicious and wonderful pork on a smaller scale in my backyard without having to dig a big ol' hole and cook an entire pig. In the process I built a dual purpose grill and hot rock BBQ.
The cooker is built from 2 dozen cinderblocks, dirt, rocks and a few other materials that you probably have on hand. With this inexpensive setup you will be able to have a two day Meatfest starting with your favorite grilled vittles and culminating in amazing Kalua pork.
Here is the disclaimer: This cooker involves heating rocks to a dangerous temperature and then covering them with potentially flammable vegetation and then leaving it unattended for many hours. If you are careless or unlucky you might burn up.
To build the cooker you will need:
24 CINDERBLOCKS - these cost me $30. This was the only thing I had to buy other than the pork.
1 STEEL OR IRON GRATE - must fit over the cooker. I borrowed one from a weber, but i didn't quite fit and I had to use a pipe to stabilize it. I bet an oven rack would be perfect!
DIRT - cheap! suitable locations for the cooker were not suitable for digging, but less conspicuous areas provided plentifully. I used one wheelbarrow full.
ROCKS - cheap or free. DANGER! USE CAUTION HERE!!! Some stones, especially those collected from a body of water could explode when heated. This might be bad for your health and livelihood. Fair Warning OK? Choose rocks sized between softball and cantaloupe. You want a couple dozen rocks.
PIECE(S) OF PLYWOOD - to cover the cooker during slow cooking. Serves to keep the heat in and keep out potential weather and varmints.
CLOTH - helps hold in the heat for slow cooking; I used an old bed sheet.
To operate the cooker you need:
FIREWOOD - You will burn wood to grill with but the most important thing is to thoroughly heat the rocks for slow cooking. It will take 3-4 hours for the stones to get hot enough.
GREEN LEAFY BRANCHES, PLANT STALKS OR SOAKED WOOD - You need enough to create a moist buffer layer between the hot stones and the pork. The authentic material is freshly cut banana tree stumps. It's wet and fibrous and doesn't burn up, so it creates tasty, smoky steam to cook the pork. In the Mid-Atlantic U.S. I had to use something more local and went with maple and hickory branches with the leaves still on. You could try some other materials too; any type wood that is used for cooking/smoking should work well here. I want to try corn stalks next.
BANANA LEAVES - This is to wrap and flavor the pork. I can get frozen banana leaves at the Latino market near my house for $1 a package. If you can't get banana leaves, you could use foil, but then it won't be Kalua Pig.
CHICKEN WIRE - optional - this helps to cradle and maneuver the pork but you could do without it...
THE MEAT THE MEAT THE MEAT - For day one, pick your favorite grilling foods; steaks, burgers, sausages, chickens, pork chops, lamb, bacon, offal and vegetables too!
For day two it's slow cooking and pork is king. Get a great big pork shoulder, with the skin on. I use the whole shoulder; it should weigh close to 20 pounds. You could do it with less, but it would seem like a lot of work for a little product. This oven is probably capable of cooking two or three whole shoulders if you wanted to. I haven't tried yet.
Step 1Build the Cooker
Build the Cooker
First, find a suitable safe place to build your cooker. There is going to be a big hot fire in it, so take proper precautions. Do I need to be more specific? Don't burn anything down or cause property/bodily damage! Ask someone who knows you well if you have any common sense before attempting this step alone. I built my oven on the concrete walkway in my backyard so not to kill a spot on the lawn, but it could be done on bare ground, provided that it is very level.
Stack the blocks on the ground in three layers of eight blocks, as pictured, to produce an open cube shape. The blocks should be straight and level, without big gaps. Be sure that the blocks are stable and will not be knocked over later when you fill them with heavy stones and fire and pork! Now is a good time to check that your grilling grate fits across the top of the cooker.
Next, fill it in with a few inches of dirt, I used a half wheelbarrow full to give about 4 inches of coverage across the bottom of the cooker.
Last step is to cover the dirt with the rocks that you collected.
22 comments
Oct 5, 2009. 7:08 PManvilind808 says:
Mmm...all you need now is the lomi lomi salmon, squid luau and haupia!
Sep 16, 2010. 11:34 AMtonnie says:
Haupia is a pudding make of Coconut milk, cornstarch, sugar
Sep 17, 2010. 11:10 AManvilind808 says:
For the open minded connoisseur, there's also Chocolate Haupia and Cinnamon Haupia! :D
Oct 6, 2009. 12:37 PManvilind808 says:
Here you go check it out. What is Haupia? Not a whole lot of people enjoy poi. Its an acquired taste. But if you add some sugar to it, you'll probably like it first off. I'm getting hungry just writing about it now. LOL
May 18, 2010. 5:43 PMxd12c says:
 You may want to switch to a fire brick of some sort or something rated for a fireplace. I have had standard cinderblocks explode on me when used in a firepit. The repeated heating & cooling causes it.
Sep 2, 2009. 10:18 PMvandal1138 says:
I would have to say that the first step to great BBQ always starts with beer.
Feb 19, 2010. 11:31 PMPentacle says:
Barley pop. Never heard it called that before. Barley pop. I LOVE BARLEY POP. Lol.
Sep 4, 2009. 4:15 AMvandal1138 says:
Agreed! It seems that all great endeavors are significantly enhanced with malty goodness!
Sep 18, 2009. 5:26 PMTheInventor1997 says:
you can also use ti leaves (a hawaiian plant) and yes its spelled ti not tea you can also take the bone out and stuff it with banana/ti leaves or use a young pig and stuff it!
Sep 18, 2009. 5:14 PMTheInventor1997 says:
ahhhhh reminds me of hawaii
Sep 11, 2009. 1:09 PMpikaj00 says:
Congrats and awesome just awesome!
Sep 10, 2009. 9:31 PMmikeasaurus says:
<high fives>
way to go on the bbq contest win!
Sep 8, 2009. 8:00 AMSNACKS says:
What time did you start the cooking of the pig? if i want to eat at 7 then I need to start - day 1- fire @ 5 -day 1- eat @ 7 - day ? start pig @? day 2- Eat @ 7
Aug 22, 2009. 8:01 AMBitsi says:
Stones, sticks and fire -- this looks like a lot of fun. Pit cooking has never seemed so possible. This might constitute the only downside of vegetarianism. Are there any non-meat foods that would benefit from 12-24 hours of cooking? A nice flavorful tree trunk or root maybe? Could this be adapted to fire ceramics?
Aug 23, 2009. 5:18 AMNewB007 says:
You would need to use fire bricks (or similar) instead of cinder blocks, but the square configuration should work. You need up to about 1730°F (945°C), where the cinder blocks would lose strength and likely crumble. Beyond that, the specifics would depend on what you want to accomplish.
Aug 22, 2009. 3:17 PMlesrebnav says:
hello, here in my hometown (new caledonia) we do this for the meal at the family reunion and we add yam, taro and sweet potato or fish. We do another meal named "bougna" , it made with yam and coconout juice inside a lot aof banana leaves. bon appetit
Aug 22, 2009. 6:49 AMjessyratfink says:
This is great! You could almost have a two day party doing something like this. :D I love that you can get multiple meals out of the grill!
Aug 22, 2009. 5:30 AMblam72 says:
Well done, this is a great instructable. I've been telling my wife for a year now that I want to try something like this. Your instrutable looks like a great way to do. I'm getting hungry already.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:Goesto11
