3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hot Rod your old Dustbuster
I finally got tired of having my old dustbuster as a nicd memory-effect demonstrator (it would fade immediately, but then after about 45 seconds come back with some usable power, annoying to wait for). So I decided to replace the battery pack. In the process I realized that I could extend run time and power, hot rodding it to a slightly higher voltage.
Step 1Background and Prep.
This particular dustbuster is a wet/dry model, about 10 years old. When I popped out the battery panel I discovered the battery pack was only 3 sub-c size nicd cells. There was room in the compartment for four, so I decided to accept the risk of an extra 1.2V from a 4th cell. This turned out to be a good move so far, although I don't expect the motor to last forever. Given the short duty cycle of typical dust busting, it should be fine. I also marked the leads on the buster so I wouldn't forget which was which.
Then I went online and found 3300mAh sub-c NiMH batteries with solder tabs (these can be found at several battery suppliers, really the only important part is to get Sub-C size NiMH batteries of any reasonable capacity. Getting them with solder tabs makes it easy to make the final pack, so I advise them. I also found out that the stock charger has a reputation for wrecking the batteries, so I'm using my smart charger instead, it's a MRC 959 super brain charger.
8 comments
Nov 16, 2009. 5:19 PMabadfart says:
how much power??
Nov 16, 2009. 8:03 PMabadfart says:
cool that will be cheaper than a robovac
May 19, 2009. 11:52 AM12V says:
the original batteries are probably 1200mah.
Jan 21, 2010. 7:48 AMGorillazMiko says:
Hahahaha! "Someone's applying their RC knowledge ;-)". Haha, great Instructable by the way.
Jan 2, 2008. 5:46 AMHands Without Shadows says:
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:rocketguy
I'm a rocket guy, and a flying guy, and a space guy. And a tech guy.
