At this point it would be good to mention you should really discharge the pack before you continue. Don't play with electricity unless you know what you are doing!
Remove these ads by
Signing UpStep 1Let's find out what is inside!
Fortunately for me the internals were looking familiar, a simple set of "Sub C" rechargable NiCd cells from my RC car racing days. I used to build my own racing battery packs so I couldn't help applying that here.
I had visions of using batteries that power world championship RC cars and transform my moderately powered B&D into a drill that would make screws and yet-to-be-drilled holes tremble with unspeakable fear.
When you open the battery you'll need to save some plastic bits detailed below. Don't break them.
I read that the tool does not care where the power comes from and I like the idea of Lithium (rechargeable type) batteries.
Where I live in Sydney Australia they don't seem to have any idea about such alternative ("they" are tools suppliers, Electric retailers, and even battery businesses, such as battery world)
Here in this thread, one get the impression that is rather easy (with some basic idea) to build such apparatus, but it makes me wonder; for instance I have a Black and Decker cordless drill only a few years old but that doesn't seem to have its original battery available anymore and with a battery replacement (mostly out of stock!) and for which there is a very tinny warning: "will not work with original charger"!
My father had an interesting saying "I'm not rich enough to buy cheap things"
I have tried similar "alternatives" with refilling my own printer cartridges, but eventually gave up the idea although it was indeed a cheaper option but at a cost although not monetary. I wonder if contemplating this battery power alternative falls in the same category.
Just the same the idea of a universal pack for cordless tool is indeed very attractive.
Hi, my cordless tool uses 1.2ah sub c cells would this matter if i replace them with 2.0ah sub c cells or would this damage the tool?
The biggest danger for the tool is to have too high a voltage, as in heavy use the motor may burn up.
The other problem is with the charger. Your charger is very specific to battery chemistry. Each chemistry has it's own needs. NiCd is the simplest to charge. Hydride batteries are more complicated to charge, and a Nicad charger will charge them but they will have a shorter than desired battery life.
Lithium cells are great, but they need a precision charger. The voltage per cell is much higher, so you could possibly put in fewer of them, with larger Ah to get better battery life per volume.
You could possibly replace the guts of an existing charger with an off the shelf charger from the R/C market to take advantage of these cells.
Oh. The simple answer is just to keep the voltage sane. > Ah won't harm the tool.
I have done a fair amount of soldering in my day and have been cautious about overheating the cells, although Ihave messed up few. Never had one explode or anything.
Hears the deal, recently was at Battery Plus and we all know that they pack batteries with a spot welder. I was explaining how and what I was doing and he said he was a fireman and he knew of someone that had a cell explode and burned up his house... He said it was extremely dangerous to do without a spot welder. He would do them for $$$. Now was this a scare tactic or what??? I have a case of SubC cells sitting in the garage wondering?? hmmm comments please. Oh I am using a temperature controlled soldering pen sith a flat screwdriver type end.
You also need to test the connections as you go so you don't end up with shorted cells or wrong connections. If you want to build a battery superior to the original battery that will run any tool at any voltage, check out the Rambo Battery. The Rambo Battery kit is simple to build and it allows you to run your tools at a few volts over the tool voltage - 14.4 volt tool running at 18 volts for example. You will really enjoy the extra power and speed you get. You can also configure a Rambo Battery using NiMH cells rather than NiCD cells for much more power.
This is absolutely false. If you "overheat" the cells you can damage them, but people have been building high-performance racing batteries for RC for decades by soldering on battery bars.
Second, this sounds like a product advertisement and I'm tempted to flag it as such.
Thanks,
Can you please tell me how to identify the dead cell ?
Thanks !
Gotta love those "Fine Adjustment" tools.
Unfortunately there are quite a few slightly different bits and if you don't have the right bit you quite often can't get the fastener out.
Now this is a real instructable.
1. It is a genuine project
2. It justifies the time it takes
3. It saves money and the planet.
4. It is well documented.
5. You have included relevant links.
6. It gets eight's approval. (The sticker is in the mail, mate !)
Here are a few thoughts n the project and various comments/questions...
I use RUSTEX (35% phosphoric acid) for tinning wires and metal tabs when soldering. It is cheap and can be used for pacifying rust on cars and steel.
You can buy very wide heat shrink tubing to hold packs together.
NiCd cells can dump much more current in a split second than NiMh.
NiMh needs a special charger.
If you use a NiCd charger it will work to a point... but you wont get the depth of charge and neither Charge or Batteries will last long.
The biggest "D size" cells I can find locally have 9Ah capacity. (9000 mAh)
These wont fit in this project, but man -o- man what a charge life :)
Many older laptops used a "A" cell ( 2.0 Ah or 2.2 Ah ).
"A" cells are same length but bigger Diameter than "AA" cells.
Since "AA" cells now have 2.6Ah capacity, you can make lighter packs when rebuilding.
FYI, Duracell make 1.0Ah "AAA" NiMh.
I have been quite busy modding various torches and other items with these smaller cells.
Sorry for a long post... Lots to say : )
link
