3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hot Rodding a Power Drill Battery
Step 5On to the Assembly
On to the Assembly
I paried the cells and bound them with electrical tape just to make them easier to solder together. These buggers are a little hard to hold on to.
Don't forget to tin both ends of the battery before you try and attach the bars. A drop of flux and a drop of solder, not too much though.
I should mention that you will need a pretty serious soldering iron to get this job done. Don't overheat the battery...kind of a catch 22 here.
5 comments
Aug 21, 2011. 5:48 AMarpruss says:
I wonder if using Wire Glue would work for the tabs? I don't know how well it stands up to the temperatures batteries reach.
May 27, 2011. 8:55 AMmotor137 says:
ok, been building my packs witha Weller Solder Station, pen. I can adjust the temp and the tip,usually used the screwdriver blade tip. Any idea what temp you think is ideal?
Oct 3, 2009. 11:56 AMRussell Nash says:
This is the place where you're most likely to screw it up. I avoided the problem by buying the batteries with solder tabs already attached.
Jun 27, 2007. 1:18 AMLiquidhypnotic says:
How powerful was the soldering iron you used here? My soldering weapon of choice is the ColdHeatPro; do you have any idea of how that would perform here?
Jul 28, 2007. 6:00 PMIan01 says:
I think you'll need something more powerful than a ColdHeat iron.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:archer6817j
