loading
Picture of Hot Wheels flash drive
Creating Hot Wheels flash drives.
Step 1:
Picture of
A hot wheels car cost around one dollar, these 8 gig  flash drive cost about $6 online.  For this project I  used a drill, Dremel, propane torch, hot glue gun, small screwdriver and needle nose pliers.
Step 2:
Picture of
Pry apart the flash drive, I used some heat shrink electrical wrap to insulate the flash drive after it is removed from the case.
Step 3:
Picture of
Take the hot wheels car apart by drilling the head of the rivets off flush with the bottom of the car. (I like to use the cars with a plastic bottom and metal top).
Step 4:
Picture of
The hot wheels cars come apart into 4 parts, the metal body, the windshield, the interior, and the bottom with wheel and axles.
Step 5:
Picture of
I use a Dremel tool to cut away enough of each section for the  flash drive to have room.
Step 6:
Picture of
Dry fit the sections together with the flash drive to check the fit. When it all fits together correctly, take it back apart and reassemble using hot glue on each layer. you have removed the rivet to disassemble, so the hot glue is now going to hold the car together and secure the flash drive in the car.
Step 7:
Picture of
When inserted into a computer the led on the flash drive will light up and be visible thru the windshield.
BrianM11 made it!2 months ago
Easy and fun to do with the right hot wheel.
Baronrc3 years ago
Two other words:
CHRISTMAS. PRESENTS.
2 words. so. raw.
