Features;
-Makes detailed work easy.
-Inexpensive (only a few dollars in parts)
-Small (easily storable)
Lets get started;
Remove these ads by
Signing UpStep 1Parts & Tools
(also the metric components can be replaced with their nearest imperial counterpart if you are in Canada or America (M5 = 5mm ~= 1/4")
Parts: (Approximate cost $15)
-Bolt (M5 x 30mm) x 2
-Nut (M5) x 2
-Washer (M5) x 3
-Bolt (M3 x 15mm) x 2
-Nut (M3) x 2
-Washer (M3) x 3
-Nut (M20) x 4 (these are used as legs to lift the board off the table so 4 chunks of anything about 15mm tall will work)
-Nichrome Wire (can usually be found at hobby shops beside their foam cutters as a replacment part)
-Battery holder (2 x AA)
-Small Cutting board (mine was 16cm x 26cm)
-Wire (about 40 cm)
-~40cm of 4mm diameter metal rod
Tools;
-Pliers
-Wrench
-Hot Glue Gun
-Solder
-Soldering iron (I used a soldering iron to melt the holes into the cutting board this is because I did not have access to a drill)
coz batteries are costly and a pain to dispose off..
It took us some experimentation to find the right wire size to make the train transformer cut well without burning out the wire, though.
This is the same principle, and a great Instructable.
For larger work, like foam rubber, I used to use old electric carving knives I found at yard sales. It also worked great for fiberglass insulation batts when I built my first house.
