3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hot-Wire Foamcutter (Battery Powered)
Step 6Assembling / Using
Assembling / Using
Time to put it all together.
1.I glued the battery holder close to the top corner (granted this did cut down on my cutting freedom so relocating this may be a good idea)
2.Attach the bent rod using the two 5mm x 30mm bolts to the two holes drilled into the top right of the board.
3.Run the long wire beneath the board to the hole in the middle of the board. Run one of the 3mm x 20mm bolts through one of the washers at the end of your hot wire length. Then feed this bolt through the hole, attaching the wire to the bottom and fixing it all in place with a nut.
4.Taking the free washer end of the hot wire, run the remaining 3mm x 20mm bolt through it. Next run this through the end loop in the bent rod, using the elasticity of the rod to pull it taught.
5.Use, attach the short length of wire to the 5mm x 30mm bolt and cut away.
Hoping that was helpful if anything is unclear (my wording can be rather cryptic at times) please feel free to ask any questions in the comments and I'll do my best to answer them.
8 comments
Sep 19, 2010. 1:30 PMprintman says:
How long can 2 batteries keep the wire hot enough?
Dec 12, 2007. 4:00 PMkhang_ho says:
Hi Clement, One more question, where can I buy a battery holder? thanks, - KH
Aug 20, 2009. 5:08 PMmacrumpton says:
Radio shack
Feb 2, 2008. 9:07 AMbrandonssk says:
you can get them for Free from Keyelco.com Thats where I get my Battery holders and stuff from.
Aug 8, 2009. 3:46 PMRiversmith says:
How do you go about getting these from Keyelco.com for free? How is it they don't make you buy them, or do you just request a single sample? Thx!
Aug 9, 2009. 11:14 AMbrandonssk says:
yes, you just go to the website, and there should be an area that says "free samples" Once you find what you want you need to put the part number in the box and then fill out the shipping info, then they send it to you :) I've only requested 2 samples at a time but i think you could go as high as 4 if you want.
Aug 12, 2009. 5:15 PMRiversmith says:
Thx for the quick response, I wasn't sure that I would get one with the post being from February of last year! Thanks Again!
Feb 2, 2008. 8:20 AMjjay10 says:
go to radio shack
Apr 24, 2008. 10:18 PMTheMadScientist says:
erm.? wow.
Mar 10, 2009. 7:49 PMPyro the maniac says:
How hot does it get? would it slice through 1/8th inch diameter rope?
Jul 18, 2008. 2:10 PMRick make sit says:
does the wire get hot only because of the current or did you had to you a resistant how much volt is the baterie (English not 1rst language)
Dec 30, 2008. 6:41 PMbombmaker2 says:
the current heats it up and the batteries are 3v
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:clement.fletcher
