Hot and Sour Soup
5,603
93
12
Published
Introduction: Hot and Sour Soup
Here it is, hold onto your hats, the best hot and sour soup recipe I've come across.
It involves a lot of steps, but it's not really that hard, just follow along and calmly work it. The original recipe came from Cook's Illustrated, but I've adapted it, enough, I hope, to call it my own. I use chicken instead of pork and since I am gluten-free, I use Tamari instead of regular soy sauce, as it has no wheat in it.
You'll want to get all your ingredients organized, lined up and measured out since some of the steps have a few sub-steps. It's well worth it, so hang in and have fun.
Important Note:
Read the entire recipe all the way through first, please. You will need a bunch of small and medium bowls for this process. So grab them as you are reading and it should help start you off on the right foot.
Hot and Sour Soup
adapted from Cooks Illustrated, 5/2006
  • 4 tablespoons tamari (gluten-free soy sauce) or soy sauce
  • 1 teaspoon toasted sesame oil
  • 3 tablespoons cornstarch , plus an additional 1 1/2 teaspoons
  • 8 ounces extra firm tofu, drained and cubed (see below for directions)
  • 1 boneless skinless chicken breast cut into 1 inch by 1/8-inch matchsticks
  • 3 tablespoons cold water , plus 1 additional teaspoon
  • 1 large egg
  • 6 cups low-sodium chicken broth
  • 4 ounces fresh shiitake mushrooms , stems removed, caps sliced 1/4 inch thick (about 1 cup)
  • 5 tablespoons black Chinese vinegar or 1 tablespoon red wine vinegar plus 1 tablespoon balsamic vinegar (see note above)
  • 2 teaspoons chili oil
  • 1 teaspoon ground white pepper
  • 3 medium scallions , sliced thin
First, drain the tofu:
  • Take the tofu out of the container, put it into a shallow pie plate (or any dish with a short rim).
  • Then, put a plate on top, and press down hard. Place two or three cans on top of the plate (I used canned beans) and leave to drain for about 15 minutes. Add more time if the tofu still appears soggy when you check it.
  • You'll know when it's ready to be cubed when the liquid has pooled at the bottom of the dish and the tofu appears much drier than it had been, but not super dried out.
  • Dice the tofu into cubes and set aside (though it's likely the broth will be simmered and ready by the time you've cubed your tofu).
Next Marinate the Chicken:
  • Whisk in a medium bowl:
    • 1 tablespoon tamari or soy sauce
    • Sesame oil
    • 1 teaspoon cornstarch
  • Thoroughly mix the chicken strips in the marinade and leave to soak for about 10 to 20 minutes.
  • The meat will become silky and somewhat fatter than it was when you began.
And Then:
  • Combine:
    • 3 tablespoons water in small bowl and mix thoroughly
    • Set aside, leaving spoon in bowl.
  • Mix:
    • Remaining 1/2 teaspoon cornstarch
    • Remaining 1 teaspoon water in small bowl
    • Add egg and beat with fork until combined. Set aside.
Start Putting it Together:
  • In a large heavy-bottomed pan, bring the chicken broth to a boil.
  • Once the broth has boiled, lower the heat to medium-low and:
    • Add mushrooms.
    • Simmer for about 5 minutes, until the mushrooms are nice and tender.
  • Add:
    • Tofu and chicken, including marinade, to soup, stirring.
    • Continue to simmer until chicken is cooked through, about 4 minutes.
Almost Done:
  • Remember the mixture you made that you left the spoon in? It's time to stir it and make it more liquid now.
  • Add to soup and increase heat to medium-high.
  • Cook, stirring occasionally, until soup thickens and turns translucent, about 1 minute.
  • Stir in:
    • vinegar (either the Chinese Black Vinegar, or the combo of Balsamic and red wine vinegar)
    • chili oil
    • white pepper
    • remaining 3 tablespoons soy sauce
  • Turn off heat.
Make the Egg Drops:
  • Get your egg mixture (the last bowl, I hope, that you have left with something you mixed earlier) and grab a spoon.
  • Do not stir the soup, make sure it's still when you start this next step.
  • Take your spoon and scoop up a bit of it into your spoon.
  • Very slowly, like you are just hanging out and not in any kind of rush, start drizzling the egg mixture over the soup, moving around the pot in a clockwise motion.
  • Let rest for a bit, about a minute.
  • Bring soup back up to a gentle boil over medium heat.
Serve it Up:
  • Remove from heat and give the soup a light stir, just enough to break up the egg drops, but not so fiercely that the nice thickness that the cornstarch leant to the mix.
  • Ladle into bowls and top with scallions.
Enjoy and savor the flavors and textures of this soup!
Step 1: Liquids and Spice
See that bottle? Chinese Black Vinegar. It's the secret ingredient for the flavor in this dish. Between this and the white pepper, it's amazing how much earthiness and valor these give to the soup.
The one thing not shown is the cornstarch, I figured you'd all know what that was.
Important Note:
Hot and Sour Soup
  • 8 ounces extra firm Tofu, drained and cubed (see below for instructions)
  • 1 large egg
Step 2: Press the Tofu
The image is of the already drained tofu, so hopefully, this will give you an idea of how it should look when it's ready to roll.
Step 3: Chicken!
    • Sesame oil
The meat picks up an amazing texture when it is soaked in the cornstarch mixture. I've read that it helps to seal in the juices of the meat, which, if the soup is any example, then, yes, it works!
Step 4: Use the Cornstarch
And Then:
  • Combine:
  • Mix:
The eggs pictured here will create something amazing in the last steps of the recipe.
Step 5: Mushrooms
    • Add mushrooms.
  • Add:
 When I can't find the shitake mushrooms, I branch out and try other kinds of mushrooms. I've worked with white button mushrooms and oyster mushrooms, and they're good, though the shitake is the best!
Step 6: White Pepper
Almost Done:
  • Stir in:
    • chili oil
    • white pepper
  • Turn off heat.
The white pepper is very pungent, use caution! As it is always easy to add more, but you can't remove it once it's in there!
Step 7:
Make the Egg Drops:
  • Turn heat back on and bring soup back up to a gentle boil over medium heat.
This is fun, don't over think it. But, do, go slow and try to make the drizzled stream as thin and consistent as possible.
Step 8: Ladle It Up
Serve it Up:
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
    12 Comments
    Very nicely done.
    This is an excellent recipe!
    The instructions are clear, detailed, and unambiguous.
    The result is outstanding.
    The listed ingredients make a significant flavor difference. Shitake mushrooms and Chinese black vinegar have distinctly different flavors from other mushrooms and other vinegars.
    I made a vegetarian version with non-shitake mushrooms and other vegetables – and flavors were missing.
    Great recipe! Thank you!
    "Chinese Black Vinegar. It's the secret ingredient for the flavor in this dish."
    +1 agreement! Search for it, it does make a significant difference!
    and, it's really affordable, too. totally worth it.
    Oh boy, so sorry, I totally forgot to add the Tofu into the ingredients list.
    It's in there now, 8 ounces, drained and cubed. Thanks!!
    Stuff happens.
    Do you use firm Chinese tofu, or soft Japanese?
    Of course there's always "in-between", but I prefer firm.
    Excellent recipe.
    I suggest a mixture of 'shrooms: consider Enoke, Forest, Crimini, etc
    I've been using extra firm, and I think it's Chinese.
    I'll try the mix next time!
    Thanks for the question. The tofu is in the first step of the recipe, where you drain and cube it. It gets added toasted the end. Hope this helps!
    This looks quite yummy. I think I'll try this recipe next time my boyfriend gets sick - this is what he always wants!
    excellent idea, no matter how sick I am, I always drag myself to the kitchen to make this and it always makes me feel better.
    So good and beautifully presented, I could almost taste it! Kudos Non-Reactive Pan!
