3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hot wire foam cutter
Step 12Turning it on
Turning it on
Set the rig up somewhere where it won't catch the house on fire or melt the carpet if something is wired wrong, or if the wire overheats and breaks. Take a moment to look over your creation and make sure all the wiring seems to make sense.
Turn the dimmer all the way down (counterclockwise).
With your fire extinguisher handy and your body away from the device, plug it in. Are the lights still on? Is the hotwire still whole? Sweet.
You can use your multimeter to see if there's any current between the terminals. There shouldn't be yet. SLOWLY (like 5 degrees per second) turn the dimmer up (clockwise) til the wire starts to quietly hum. With the wire I used that's about 1/4 or 1/3 of the full rotation. If the wire doesn't hum or heat up by the time the dimmer is halfway up, turn the dimmer all the way down, push in til it clicks, and start again.
If you turn up the dimmer too fast, your wire may burn out before you realize that it's even hot.
Once you are sure everything's all set, grab the frame and try laying the wire on some scrap styrofoam. It should slice smoothly into the foam. You shouldn't have to push very hard. Try playing with the dimmer switch setting to get the best cut. I've read that cutting slower and cooler makes a smoother cut.
The wire heats up and cools down within a second or two.
Next time you use the foam cutter, make sure nothing meltable or flammable is touching the wire when you plug it in, just in case the dimmer isn't off.
1 comment
Dec 5, 2009. 8:59 PMtb17mccoy says:
I did everything in your instructions except I made my frame out of 1/2 ' pvc but everything else I did as you instructed including the crappy plastic box. I couldn't  find a 120v 25 with only 2 amps so I used a 120 24v 40 va transformer and put a 3 amp fuse on the hot side between the dimmer switch and the transformer. I tested it in my Garage and all worked well. I cut a test piece of foam cut like butter. Thanks you saved me about $ 140.00
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:flywoodkb
