3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hot wire foam cutter
Step 5Attaching the lead wires to the frame
Now we're going to attach the wires that carry the 25V current to the cutting wire. We'll use two machine screws as terminal posts.
First, cut off each end of your 12 foot extension cord. Save the plug and outlets for future projects, if you like. Strip the insulation off the last inch of one end of one wire of the cord.
Insert a machine screw in the top of the right leg of your "big H" as shown in the photo. This is the leg that is on the other side of the H from the handle. Use one washer on the screw head side and two on the nut side, as shown in the second picture below. Put the nut on, but don't tighten it down at all. You need room between the washers so you can put your wire in there.
Bend the bare wire of the extension cord (the part you just strippeed) into a U shape, and hook it around the screw between the two washers. Now you can tighten down the nut. You can see what the final hook-up looks like close-up in the photos for step 7.
Starting the the end you just hooked up, pull the two conductors of the cord apart so that it's split for about 3 1/2 feet. Cut the unmounted side of the split to about one foot. Strip the end of the one foot section and mount it to the other leg of the H the same way you hooked up the first wire. You'll see what I'm talking about here if you look at the photo.
Use cable ties, twist ties or string to keep the wire close to the frame so it won't get in the way when you're using the tool.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:flywoodkb
