3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hot wire foam cutter
Step 7Attaching the hot wire
While you are hooking up your wire, try to avoid making any kinks it.
Your guitar string should have a sort of a bead (for lack of the proper name) on one end. Make a loop by feeding the other end through this bead. Hook the loop over one terminal and sinch it up. Keep the loop pretty close to the nut or there will be too much twisting force on the leg when the wire is tensioned. But also make sure it's not touching the wood.
To hook up the other end of the wire, pull the frame legs towards each other so your string tensioning loop on the other end is taut. Wrap the end of the wire around the other terminal screw and twist it off. See the second photo. It might help to use pliers to keep good tension, but be careful not to pull too hard and break the wire.
If the wire is not super tight at this point, don't worry. It can be kind of floppy when plucked but should be pretty much straight when at rest. We'll add more tension later.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:flywoodkb
