Step 8Cross strings
Tie a loop in one end of a 3 foot piece of string and hook it under the washer of one of the middle screws. See the photos. Thread the other end of the string though the opposite leg's hole. Square up the frame and tie off the string. Repeat with another string for the other side, but when you tie off the string at the top of the leg this time, make sure you have some tension. Now both of the criss-cross trings should be pretty tight, and there should be some slight tension on the wire too. It's ok if the tensioning loop is a little floppy at this point. Now you can tighten down both of the middle screws with the wrench. No need to chrush anything, just make 'em tight enough to hold everything together.
Add Comment
