Hotrod Your Guitar - Lower the Action
Why did Bryan Adam's fingers bleed in the summer of '69?
Because every fricking guitar you can get near has a PAINFULLY HIGH ACTION (height of strings)
Guitars with sweet low actions do exist, but there's already a dude/ette with no biceps playing it 24 hours a day and going without food.
Here's how to lower the action of your own guitar.
It'll feel so good you'll play it instead of eating/bathing/sleeping.
There won't be anything left of you but bad posture and enough hair to comb over your face.
The cheap ones start out too high. Old ones get that way over time from the tension of the strings.
For examples of both kinds, I'll be dropping the action on this Chinese-made "Backpacker guitar" that cost me a penny brand new (plus $24.99 shipping on ebay) and also an original Martin Backpacker.
Step 1Go Nuts on the Nut
Go Nuts on the Nut
You probably want your strings as low as they can be without buzzing while you play.
That depends a lot on how you play. If you play hard you'll need the strings to be higher or they'll buzz.
If you play slide or bottleneck guitar, you'll want the action higher still.
In fact, if you use the slide all the time, you don't really have to use the frets, and there's no such thing as an action that's too high. Keep that in mind when you get a free guitar with a really bent neck.
Regardless of your situation, the best way is to find a guitar you like playing, and measure the action
If you only have access to the one you're working on, just whittle down the notches in the nut and bridge until you like how low it is. If you wittle too low you can put a drop of superglue in the notch and let it dry. Or put a piece of paper under the string.
If your neck is straight and your fingerboard is flat, you'll be able to put them lower.
Here I am whittling down the nut notch on the penny guitar. You can use a triangular file if you have one.
Play with the string and sight down it. The nut notch should be as deep as if there were another fret there holding up the string. In other words the string height differece between the nut and first fret should be the same as the difference between the first two frets.
39 comments
Feb 7, 2012. 3:36 PMfreeza36 says:
how much is the cheap chineese made backpacker? i was looking into a backpacker, but at 175 used..... yeah....
Feb 7, 2012. 1:35 PManicho56 says:
thanks, useful article and will give me confidence to tamper with my son' s cheapie guitar.
however i own a martin backpacker and wouldn' t touch the action. use (elixir) 47 to 10 strings and it' s just fine. recommended to have those strings as no truss rod. low action and heavier strings risks deforming the neck.
cheers and ta
Dec 22, 2011. 10:23 AMmijfender says:
Considering experienced guitar techs take tons of practice and many many attempts learning how to properly slot a nut, I would highly un-advise doing this on anything BUT a penny guitar until you know what you are doing.
Jun 20, 2011. 9:28 AMwbufe says:
Are people getting hired to write fake reviews of this thing?
Mar 25, 2011. 4:11 PMsaltoh says:
or if youre using an electric guitar ( usually a nice one that you dont want to ruin by cutting the bone made nut) you can turn the knobs on the 2nd part of the bridge and it will lower them and not worry about getting any buzz
May 19, 2010. 4:23 PMteapotking says:
 My guitar (electric) was only £190 (or about 275 Dollars if you're american) and It has a really low action, but doesn't seem to buzz =P.
May 1, 2010. 3:16 PM27hippie420 says:
what i did to lower the action on the nut is actually grind it down with the string itself like a saw, then you know it will fit the string perfectly!
Dec 10, 2009. 1:44 PMddavel544 says:
Good Instructable....now maybe I'll be able to learn too play that  cheap acoustic I got off of ebay. Strings are killer high!
Nov 16, 2009. 2:19 PMoctopuscabbage says:
this instuctable was good right up until you got the green suite on. now im just confused.
Nov 16, 2009. 10:34 AMspeeddemon93 says:
Good instuctable, but I wouldn't really recommend whittling down the nut or bridge, it is pretty likely to cause tuning problems
Mar 26, 2009. 6:45 AMDuf999 says:
Thanks to you, my cheap old guitar is now easy playable. Good Instructable !!!
Aug 26, 2008. 12:48 AMskabonner says:
thanks i play ukulele and have one with extremely low action and love it. unfortunately I recently smashed a $15 ukulele because it had and unplayably high action
Dec 10, 2007. 3:25 AMrimar2000 says:
A yank made of a piece of bone sounds better than plastic made yank.
Aug 8, 2008. 11:12 AMbustedit says:
any yank is a good yank, as they say
Aug 8, 2008. 3:05 PMrimar2000 says:
OK, if you say it...
Jan 25, 2008. 8:21 AMAprhys says:
I have an old Epiphone archtop (1933 )that either has a non-adjustable trussrod or was made before trussrods. It had a big bow when I got it. I hung it from the wall by the headstock primarily as a decoration with the strings tuned down and low and behold the neck eventually straightened out! I keep it tuned down for slide so it won't bow again.
Jul 7, 2008. 7:57 PMn0ukf says:
if you want to play it more often, try lighter gauge strings on it if it has heavier ones on it. Lighter strings, less tension, less bow.
Jul 8, 2008. 10:35 PMAprhys says:
I've got 10's on it which are extra light in the acoustic world and lights in the electric world. You made a very valid point I'm sure will benefit many.
Jan 25, 2008. 12:09 AMalvincredible says:
LOL i like this!
Dec 13, 2007. 4:05 PMDavvik says:
I wouldn't use weight to flatten my neck (it's very bad for it) I would always make truss rod adjustments (The truss rod is wood not metal so if you turn it too far IT WILL SPLIT...rendering your guitar useless). I wouldn't use a heat gun to remove a stationary bridge, you will do more damage to the inside of your guitar then you think (it will buzz like no tomorrow). And make sure you aren't drilling through anything important when you are attempting to add a strap on a hollowbody. You can trust me on this I build them. (also the more holes you drill the more your tone will change).
Dec 27, 2007. 7:04 PMAprhys says:
From "How to adjust your trussrod" by Gene Imbody
"In its basic form, the mechanism is a steel rod with an anchor at one end and an adjustment nut at the other. It is inlaid (usually in a curve) into the center of a neck. Tightening the adjustment nut pulls the rod straight, thus straightening the neck. Loosening it allows the neck to move with the influence of the strings, consequently allowing the neck bow."-Gene Imbody
http://www.athensmusician.net/archive/2001-05-01_geneimbody1.shtml
From Wikipedia:
A truss rod is a guitar part used to stabilize and adjust the profile (also called the relief), of the neck. Usually it is a steel rod that runs inside the neck and has a bolt that can be used to adjust its tension. The first truss rod patent was applied for by Tim McHugh, an employee of the Gibson company, in 1921[1], although the idea of "truss rod" can be encountered patents as early as 1908
http://www.stewmac.com/shop/Truss_rods.html
Dec 18, 2007. 11:08 AMAprhys says:
Truss rods are metalnot wood.They are anchored in the wood of the neck. If you want to see one go to stewartmcdonald.com they sell parts and Luthier supplies.
Dec 18, 2007. 5:37 PMDavvik says:
Actually you're only part right...Truss rods have metal ends (one so you can anchor it into the wood and one so you can adjust it). They are wood (That is why they are very easy to split when adjusting your neck)
Jan 24, 2008. 3:27 PMlukieh says:
Actually, truss rods are metal... If they were made of wood there would be no point to them as they wouldn't serve the purpose of stabilising the neck against the tension of six steel strings.
Dec 27, 2007. 6:55 PMAprhys says:
A file will give you much greater control over how much wood you remove.
For more information or tools check out Stewart McDonald at
http://www.stewmac.com/ They sell luthier tools, parts, books, DVD's Etc.
Dec 20, 2007. 10:17 PMLaserCo says:
Great post, thanks I learned a lot!, I have used the crazy glue and a file before.
Dec 20, 2007. 6:12 PMarmorwaxer says:
u no you can just turn the truss rod.......
Dec 17, 2007. 1:52 PMmadhops0620 says:
What about fret buzz? It seems like your just asking for it.
Dec 14, 2007. 7:29 PMThe Pusher says:
This may work for people who want a easy remedy to playing properly but when you put on a thick string and want to bend it you will find it alot easier if you learn bending on a high action guitar, in fact I intentionally raised the action on my guitar to allow it to be more versatile and to gain hand strength but to each his own.
Dec 11, 2007. 3:11 AMstasterisk says:
What is "action"?
Dec 13, 2007. 8:53 AMRocketManDave says:
The distance between the strings and the fretboard. It's much easier to play if the gap is small, but better for slide guitar playing if it's a large gap.
Dec 10, 2007. 2:22 PMbabblin5 says:
Very nice! Thanks for sharing... excellent info! =D
Dec 10, 2007. 1:41 PMsploge says:
this is a really good Instructable it gives a lot of information 10/10
Dec 10, 2007. 1:27 PMtatakai says:
This might work on this guitar but not on an acoustic or electric guitar. Dropping the strings like this will mess up the harmonics.
Dec 10, 2007. 4:48 AMgmoon says:
Nice one, Tim!
A note: most guitars, even cheapos, have an adjustable truss rod. If the neck has too much 'bend' you can use to straighten the neck (I personally wouldn't level the fret until the neck relief was to my liking.)
Too much 'relief' is very common in older guitars--the string tension pulls the neck forward.
For most guitars:
Tighten the truss rod to bend the backward (away from the front.)
Loosen it to bend forward.
They work by compressing the neck--the fret board is denser than the neck, so tightening the rod pulls backward (the wood in the back (neck) compresses more than the front (fretboard)...)
Don't just crank way. Adjust the rod in 1/4 or 1/2 turns of the nut. Some of the adjustment will be immediate, but it may take a day or so (especially for 'relaxing' the neck--and doubly so if the neck isn't strung.)
Dec 10, 2007. 8:39 AMgmoon says:
Sure! They probably have truss rods, just non-adjustable. The most common cause of incorrect relief is storing the guitar in the attic or other hot place for long periods--either with no strings, or under heavy tension.
The other main cause is using a set of strings that the guitar wasn't designed for: I.E., a heavy 'jazz' set on a skinny rock guitar; or thin (.09) R&R shredding strings on an old beast that was designed for a set of 0.14s.
I should also have mentioned that some adjustable truss rods are 'bi-flex.' They not only pull, but they push, also:
They have a loose 'center' setting, which is no tension. From that point, turning the nut in either direction results in tightening--
Turn clockwise to compress the neck wood (more convex fret board.)
Counter-clockwise to expand the neck wood and compress the fret board (more concave.)
Dec 9, 2007. 6:39 PMjoejoerowley says:
Cool guitar! Great instructable!
Dec 9, 2007. 3:05 PMGorillazMiko says:
ah, cool. i think my brother would like this, he is always trying to change up his action on his fender telecaster. :D
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1186
Author:TimAnderson
Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional ...
more »
