Step 3Straight - Edge Guitar
Lay it on the fingerboard and see where it lines up with the bridge. Then eyeball that.
You could measure it also if you're confident you know how high you want the strings to be at that point.
If removing the saddle completely isn' t enough, you can sand down the bridge a bit.
If that's not enough you have two options: Either do an operation called "re-setting the neck" which is tricky. Or you can call it a "slide guitar" and suddenly a high action is a virtue.
comment
Add Comment
Add Comment
