Materials
Sheeting fabric – you will need a piece 75" x 22" (190cm x 56cm) for a standard 30" x 20" (76cm x 51cm) pillow
Matching thread
You will also need a sewing machine, pins, a pair of cutting-out scissors, an iron, a long straight edge, a tape measure or steel rule, a T-square or a sheet of A4 paper and a “disappearing” felt tip or a water-soluble crayon in a colour that will show on your fabric.
Remove these ads by
Signing UpStep 1Cutting out
Start by pulling a thread at the cut end of the fabric to give you a straight edge perpendicular to the selvedges. Cut along this line. Measure 22"/56cm (or whatever width you need) along each selvedge and mark those points with a "disappearing" felt pen or a water-soluble crayon. Measure and mark at various intermediate points too and then draw a line along a straight edge from one selvedge towards the other, to 75" (190cm) or whatever length you need. Draw in the short edge too, taking care to make it at right angles to the first line. You can use a sheet of paper to give you the right angle. Now cut out the rectangle.
Add Comment
