3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Housing 3 male betta fish in 1 ten gallon tank
Step 3The solution to the problem.
After going to all of the home improvement and pet stores in the area, I finally decided to use perforated vinyl siding. There were no other options that I could figure out in a timely manner.
I thought of the siding right away, but I was looking for an alternative.
I thought that vinyl siding would look bad, and I didn't want to buy a giant piece of it since I only needed about 2 feet of material.
There was some good news, though:
The siding fits easily in the channels that came with the divider set.
The vinyl siding has less holes than the clear plastic, but the holes are larger, and both sides are fairly smooth, so I didn't need to polish any of the holes to get rid of rough edges.
The siding is more rigid, so I didn't need to use the top and bottom stabilizer pieces that came with the original tank dividers, and it ended up looking much better than I thought it would.
The area of the vinyl siding with the holes in it was wider than 10", so
it was easy to cut out the size that I needed and keep plenty of holes for water circulation.
My finished pieces were about 9 3/4" wide, by 11" tall.
After I had the pieces cut, I made sure to clean them thoroughly with warm water while rubbing them down with a mild abrasive sponge. Then I rinsed them several times, also using the sponge.
Hopefully that removed any residue that may have been there from shipping and sitting in Home Depot.
I think that they can get a glimpse of each other once in awhile, but none of them have gone into full fighting posture since I installed the new vinyl dividers.
It turns out that the aquarium looks even better than the vases did. The flat pieces of glass
don't distort the image of the fish, and you can get fairly good pictures of them as well.
*** Success ! ***
Now there are 3 happy bettas, and 2 happy betta owners in the house !
Here is a picture update with some aquarium additions and matching style backgrounds. These fish are very inquisitive, and they love having something to look at.
*** UPDATE 3/15/2012 ***
I have decided to add the following information to the end of this instructable regarding PVC, which is what the soffit is made from, since my comment in the comment sections seems to get missed a lot!
Hey all, I just got an answer back from Owens-Corning, the makers of the siding that I used in this instructable: "I am writing you regarding your question around the possibility of vinyl leeching once it is exposed to water for long periods of time. The vinyl siding or soffit in this case by its nature of chemical bonds will not breakdown when exposed to water, or leech any materials used in the manufacturing of the vinyl. Once the materials used to manufacture vinyl are combined the bonds of the material can not be broken down, hence the reason vinyl is 100 percent recyclable. In fact vinyl is used as a liner and cap for many landfills because it is inert and stable."
The only time this material can be hazardous after its manufacture, as far as I know, is when it is burned, which would be difficult if it's in your fish tank!
20 comments
Mar 15, 2012. 3:17 AMstephanie2240 says:
Have you not had any problems with the vinyl siding poisoning your fish? I did this for four bettas in my ten gallon tank, but the water got really cloudy and they seem like they are about to die. I had the water tested at petsmart and it was a little hard, so I got a water clarifier for it, but the next day the water still had not improved, and my four fish look like they are about to die /:
Jan 19, 2009. 2:58 AMhandysmurf says:
how did you set up your filter? I tried the divider thing because I had a female that was VERY aggressive and the other female was passive ... or ... terrified. my divider appears to be the same brand or whatever but isn't clear it is opaque. So anyway ... I do have and use a powered filter but even though the divider is perforated it only filters one side well. Actually I once had a pair that successfully spawned and hatched a brood in an undivided 10 gallon tank with a powered filter. .. with no "spawning leaf" or other apparatus to boot ... they also had a tankmate .. a "fresh water lobster" whatever that is LOL
Feb 23, 2012. 11:51 AMCandor says:
It's actually not a good idea to keep less than 5 females together in a sorority. The number allows them to keep from making a pecking order (or, as I like to call it, a picking on order.) And for 5 females a 10 gallon tank is much too large, for the same reason. Female bettas are one of the few fish you truly want to over stock, just to curb the aggression. If you keep them in 10g I recommend having at least 15 in one tank.
Apr 17, 2009. 5:08 PMbassmonkey says:
your female could be an immature male, they aren't supposed to be aggresive, or she might not have enough room
Apr 17, 2009. 8:37 PMhandysmurf says:
naa she became bloated with eggs ..... definitely female
Sep 13, 2009. 1:25 PMkrissilion says:
Are you sure you not just feeding it to much?
Apr 18, 2009. 7:21 AMbassmonkey says:
that's odd, how many gallons is your tank?
Apr 18, 2009. 1:57 PMhandysmurf says:
10
Apr 18, 2009. 6:08 PMbassmonkey says:
hm. your a tough case (not an insult) so i would (a) get a 5 gallon tank for her (b)sell/give her away (i am not that kind of person, but it's an option) (c)get slightly bigger tropical fish than your Betta. i'm not sure this would work, but even fish have to pick their battles
Jun 13, 2011. 8:24 PMWhyHello says:
I've heard matal can be bad in fish tanks, my fishly wisdom is very wimpy so....
Mar 8, 2011. 10:09 PMahallock-1 says:
Anubis--This is a wonderful instructible. I'm happy that you upgraded your bettas. Having had bettas in the past, I can tech support one of your problems. When you moved them from their individual "puddles" they had been living in, and moved them into closer quarters, they began fighting over territory. In their homeland, they live in heavily planted areas that divides them up into natural territories of pockets of small pools of water. When you upgraded the size of their pools, you missed the critical step of upgrading the greenery that helps shield and define their territory. Bettas are actually happiest in a heavily planted aquarium. (Not under plants, but amongst them.) If you add things like Java Fern, water onion, certain types of lily, and many other very easy to grow aquatic plants that all live below the water line, not only will the fish be happier, and thus healthier, but it will also mean that your aquarium water is more stable, as the live plants help filter the water and also cut down on the growth of algae. Best of luck with your fishie friends.
Jan 1, 2011. 5:30 PMjupeter5 says:
Wow, nice work looks great.
Dec 28, 2009. 1:22 AMkomecake says:
  Okay. Here goes. I'm pretty new to Betta's. I ended up with one at a White Elephant Gift Exchange. LOL. I have 3 pet rats and so I tried to give it away (though I really wanted it), but couldn't. So, alas, with Christmas money I bought him a bigger tank, 5 gallons to be exact. It was the best tank I could find for a filter and light and had GREAT reviews for Betta's (I'm really obsessive about getting the best of best and all the correct information before I buy something).
 So anyways... I want another one. Haha. I got the Eclipse 5 Hexagon tank because I needed something that would fit in my room. I kinda wanted the standard rectangle they had in the same brand, but again, I needed something that was a space saver. So now I have this oddly shaped tank and I want to split it so I can add another Betta. This makes me wish I hadn't given away my 10 gallon tank a couple months ago though... oh well.
 Anyways, I had no real point to this comment. I just wanted to thank you for the ideas. I saw a Betta at Wally World that I want. Most of them looked very sickly though. *sigh* Do you have any suggestions on a better place to buy a Betta? Petsmart's seemed okay and I know there is a Petsupermarket nearby. Btw, your tank looks really great! :)
Aug 16, 2009. 10:48 PManimal lover 1112 says:
the reason the bettas started getting mad is because they are natural fighting fish there real name is chinese fighting fish
Sep 13, 2009. 1:24 PMkrissilion says:
Hahaha. I am sure the person with 3 of them knew. In a week I am getting a 10 gallon just for 1 betta. =]
Nov 10, 2008. 2:15 PMhopdevil says:
Nice article, the Vinyl siding you used is used for the soffet under the eaves of the roof.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:TheRealAnubis
I usually end up doing an instructable because I have to figure out how to do something myself. I just get pictures during the process, and if it works out, BOOM, an instructable!
