3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hovercraft Model No. 2
In this instructable, I'll go through what I did to acheive greater balance than the standard hovercraft. I havn't done anything for propulsion, however this can be acheived without much difficulty. One of my goals of this model was to have the ability to tote it around in my car (a saturn) as well as support my weight.
Step 1Acquire Materials
Acquire Materials
This project isn't nearly as inexpensive as my first model. This model cost over $150 with all new parts and took about 13 hours to build and 3 trips to home depot.
3 Pre-cut Particle Board Circles 2 foot diameter (3.68 each)
5 Street Elbow 90° Fittings 3" (3.38 each)
4 Hub to Hub Elbow 90° Fittings 3" (2.19 each)
3 Flanges 3" (2.99 each)
1 Double T 3" Fitting (13.78)
1 Five and a half by 7.5 tarp 10 mil thick (6.98)
1 Ten foot PVC Tube 3" (12.08)
total cost (before tax): 158.41
The leafblower I got as a gift (my friends know me well) but it fit snuggly inside the 3" pvc tube.
26 comments
Feb 17, 2011. 7:13 AMMillenniumMan says:
Marty: Here's your hoverboard back kid. (holding pink barbie mattel board)
Little girl: Keep it, I've got a Abyzaran now :)
Jan 23, 2010. 1:22 PMrhino21 says:
I want to know how much weight this hovercraft will hold up. I see it says it can hold you up, but I would like some concrete numbers or at least estimates
Jan 25, 2010. 10:27 AMrhino21 says:
How fast does it go?
May 26, 2007. 3:35 PMjrgcool35 says:
Why three trips to Home Depot? Cant you just get everything in one trip?
Apr 17, 2008. 8:36 AMeagle_02 says:
You never just go to Home Depot once. It just does not work that way.
Apr 19, 2008. 5:42 PMkcy123 says:
it depends on how much stuff you need.
Apr 10, 2008. 1:32 PMbotmaster 10 says:
depends on the size and capacity of the car
Jan 11, 2008. 8:59 AMDeusXMachina says:
:laughter: It's not unusual for my build team (ok it's me and my best friend it's still a build team though :-P) to make 2-3 trips to Depot in the same day, over the course of a several day build. I think the most we've been to in a 24 hour period was Wal-Mart, Lowe's, Home Depot, and Curtis Lumber. It's all within 3 miles so we're not killing the environment.
May 26, 2007. 3:37 PMjrgcool35 says:
I have a feeling you copied this from the myrhbusters show when Adam and Jamie both make hovercrafts. This is Adam's model... If you look at them they are basically the same.
May 27, 2007. 7:55 PMbrainiac says:
o i think he did
Oct 5, 2006. 11:13 PMSk8rDuck says:
On myth busters they made hovercrafts like this. I think they are so cool. I wish I had the time, money and the stuff to make one.
May 4, 2007. 12:26 AMmcraghead says:
"I wish I had the time, money and the stuff to make one"
Make one of these: Simple Hovercraft ...it works way better than you think; there's nothing like that hovering feeling. No propulsion, but you could use a big stick and push yourself along like they do in Italy. With their hovercrafts.
May 14, 2007. 11:33 PMSpl1nt3rC3ll says:
Just add a small fan to the back, thats what I did.
Mar 18, 2007. 12:19 AMinstructa-fan says:
does anyone know of a quieter and faster fan for this???????
Oct 8, 2006. 4:34 PMTheMadScientist says:
sorry for the bad picture... i cant draw on paint for crap
Oct 8, 2006. 4:33 PMTheMadScientist says:
can the air cushon setup be something like this?
Oct 6, 2006. 9:32 PMIan01 says:
Try fastening the center of each piece of tarp to the board. Also try a ring of small holes instead of 4 big ones.
http://amasci.com/amateur/hovercft.html
Oct 6, 2006. 10:27 AMHovercraft says:
Good work man. My first model hovercraft about 15 years ago used lift cells (as I called them) similar to yours. My rational was that I could simply add cells to increase cushion area. However, this idea doesn't pan out due to 2 critical issues. 1) the extra ducting required to pull it off increases the weight of the craft (that's a no no). 2) the key to hovercraft payload capacity is the cushion's total area. Using cells instead of a single large cushion, decreases the total area available for lifting the hull. So, two hovercraft design sins are committed at once. Decreasing the payload capacity (the area) while increasing the payload (via the extra ducting). It looks like it was a fun build though. Keep up the good work but maybe consider the purchase of a book such as "Light Hovercraft Design" by Chris Fitzgerald available from the Hoverclub of America to non-members.
Oct 5, 2006. 11:39 PMDoom_Goat says:
when you say 'off i went' do you mean you had a propulsion system? ive always been curious as to what could propel a hovercraft
Oct 6, 2006. 1:47 AMpjax says:
a simple fan that blows out back could propel a hovercraft
Oct 6, 2006. 10:39 AMcchance says:
interesting but technically a small fan shouldhvae been able to move you forwad, it would have required less force if you had gotten more lift probably.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Abyzaran
