Hovercraft for Vg100 Course in UM-JI
Published
Introduction: Hovercraft for Vg100 Course in UM-JI
Introduction
We are Team V for the Vg100 Course of the UM-JI, our Hovercraft attended the TT and tournament of the hovercraft race. However, no videos were made during the game. It is a real pity.
1)The Um-SJTU Joint Institute is located in Ming Hang campus of ShanghaiJiaotong University, SHanghai,China.
2)In the Vg100 course, every group builds a hovercraft for time trials and tournament.The racing route includes straight road and several curves. For time trials, groups can choose to run one or two rounds, only the time for final round will be recorded and the time limit is 3 minutes. For tournament, the two participants randomly decide their route by throwing a coin.
3) The hovercraft must float but can have contact with ground. The hovercraft is not allowed to take a shortcut when turning the curve. Two hovercrafts can have collision but intentionally crushing is forbidden.
Object
Mechanism for reducing friction
Limits
Lifting height
2cm
Mass
800g
Size
30*30*30cm
Battery
2*12V
Motor Voltage
12V
Central control circuit
Arduino system
Remote-control
1(at least 1)
Lifting height
2cm
Budgets in RMB
EMAX 12g Servo
17.5RMB(2.82USD)
SkyWalker 20A ESC
44RMB(7.09USD)
Nylon Helix stand M3*2
12RMB(1.93USD)
T-shaped wire
6.5RMB(1.05USD)
plexi glass
100RMB(16.11USD)
EMAX2212 brushless motor
40RMB(6.44USD)
APC 4.7*4.7 propeller
2.2RMB(0.35USD)
Lion Li-po 3s 1200mAh
48RMB(7.73USD)
Colored wires
4.8RMB(0.77USD)
Flower Li-po 3s 1500mAh
72RMB(11.61USD)
10*10*200 light wood stack
1RMB(0.16USD)
Motor holder
4RMB(0.64USD)
Skywalker 40A ESC
52RMB(8.38USD)
64mm Ducted motor KV4500
80RMB(12.89USD)
Arduino UNO
168RMB(27.08USD)
PS2 handset
40RMB(6.44USD)
M3 Nylon nut
5RMB(0.81USD)
Total
697RMB(112.35USD)
Step 1: Step1 Cutting the Board
Before assembling the hovercraft, we should do some preparations. First, we use the laser cutter to cut three acrylic plates based on our CAD graphs to be the frame of the hovercraft. The three plates are supposed to be cut into a small ring A to lock the ducted fan used for lifting, a bigger ring B to be the main body to support other components and let wind blow down, and a small disk C to help evenly distribute the wind and keep balance.
Step 2: Step2 About Coding and Remote Control
Second, we write a program using Arduino IDE, and we expect the program to achieve the functions of remotely controlling the hovercraft to start, stop, and turn using PS2 hand set
Step 3: Step3 the Skirt
Third, we cut a piece of longrectangle cloth from a raincoat, with its length a bit larger than the outer perimeter of the B plate.
Step 4: Step4 Assembling
After these preparations,we can start to assemble our hovercraft. We first connect the A plate and the B plate with the ducted fan stuck in between by plugging the nylon columns in the holes on the plate and fix them with nylon nuts, and we connect the C plate to the B plate using similar methods. Then we fix the propulsion motor on the motor holder and the motor holder on the servo with screws and some glue. We need to fix the servo with the motor and the holder on the wood stick with a screw and tie them with insulating tape tightly. Next, we plug the wood stick in the hole of the B plate and glue it on the C plate. After that, we surround the skirt on the B plate and glue it to make sure the width of the skirt under the B plate is equal everywhere. The next step is to place the components on the B plate. We connect the wires according to the circuit diagram and fix the wires by insulating tape to the Arduino board. We again use insulating tape to fix the batteries, the signal receiver, and the wires on the B plate, and use screws to fix the Arduino board on the plate.
Step 5: Step5 Finally
Finally,we will test the running condition of the hovercraft. We can adjust the weight distribution to make it balanced enough, and adjust the program to make it easier for the controlling.
    • Clocks Contest
      Clocks Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
