This is a pretty simple Infrared Harp. The sensors work like on/off switches to trigger various sounds when they are plugged into your computer's music program. With the MidiTron you can use any type of analog or digital input device, from temperature sensors to regular switches, to trigger your sounds. Get creative, it's really fun to think about all the things you could play!
http://www.2pointhome.com
MATERIALS:
- Epoxy
- 8 - 10 Infrared Sensors
- MidiTron
- 22- 24 gauge wire in red, black, and yellow
- Needle nose pliers
- MIDI to USB converter
- Two 4 - 6' aluminum u- channels
- Two 4 - 6' of 2 x 4 wood
- Large SPST On/Off Switch
- Wood Screws
- Drill
- Stepper drill bit for drilling through metal
- Zip ties (small)
- Zip tie mounts
- Wire Butt Connectors (small 26 - 24)
- Crimper for the connectors
- Multimeter for testing connections
- 9V 300mA power supply with connector
- Solderless Breadboard
- Box of jumper wires
- Jewelry screwdriver set
- Music software like Garage Band
- MidiTron Software
- USB Driver software
Remove these ads by
Signing UpStep 1Test the Infrared Sensors
Place the wires from the sensors into the corresponding channels of the breadboard. Use jumper wires to connect the yellow wires to the MidiTron. Now connect the power supply to the MidiTron. Then, using a jumper wires, connect the MidiTron to the vertical channel of your breadboard.
comment
Add Comment
Add Comment
