3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How ANYONE can make a linocut
If you’ve always wanted to make your own custom-stamped cards, patches or invitations, but feel like you’re out of luck since you aren’t a master illustrator, this instructable is for you! No drawing skills? No tracing ability? No problem! If you can carve a pumpkin, you can make a linocut. I’ll show you a handy shortcut to making your own linocut and you’ll be block-printing away in no time.
This instructable includes a photocopy transfer technique to apply an image to your linoleum block, an introduction to carving linoleum, ideas for embellishing your block print with color, and tips on printing on to fabric and scrap paper.
You’ll need:
A set of carving tools with different tips ($6-$10 for a starter set)
A linoleum block ($1.29 for a 2"x3" piece & up)
Block-printing ink ($3.79 for a small tube of water-soluble, a couple extra dollars for oil)
A brayer (I got a 4” hard rubber one for $7)
A barren (optional; $6-$20)
A plate of glass for ink, or a flat-bottomed glass dish (around the house)
Use of a printer or copy machine & standard paper
Cards, scrap paper, or fabric to print on
Step 1First thing's first- what are you making?
First thing\
Before you buy any materials, you need to decide what your end result will be. I tend to be a spontaneous art-maker, but this is one thing that benefits from planning ahead of time.
Do you want to make your own wedding invitations? How about some postcards or patches for your band? You’ll need to know the size of your final product so you can select the right size linoleum block for your project.
I usually make art cards with card blanks (a heavy cardstock with a shallow pre-bend) in a 5”x7” size so that they are easy to frame, so I use linoleum blocks that are 5”x7” for that purpose. I find it is easiest to use paper that is the same size as your block when you’re printing.
You can print on most smooth surfaces that will hold ink. Paper is ideal, fabrics with a mild texture work best. You can use either water-soluble inks or oil-based ink for paper; it’s best to use oil-based ink for fabric or wood.
12 comments
Jul 4, 2010. 7:04 PMBasy says:
I use linocuts to print on fabric, they have lasted me a good ten years. I usually glue the lino to a piece of plywood. I use a sponge roller instead of the brayer and an old tray to roll the paint on and old spoons. I will try and do an instructable on this in the next few weeks.I use a linotool that is just a handle and then there is about 10 types of different blades that can be used with it. They come as a set. I find these a lot better than the linotools you buy for wood carving. I use fabric paint.
Jul 1, 2010. 7:38 PMCreativeman says:
Another well done instructable, trucdart...good job. cman
Jul 1, 2010. 1:23 PMangelabchua says:
this is awesome! i wonder if this technique would work with fabric and some fabric paint....
Jul 1, 2010. 4:17 PMcartman550 says:
You can- it would be like using a rubber stamp! If you can find a book published by Reader's Digest (way back in 1979) called Crafts And Hobbies, there's a chapter on printmaking and linoleum cut block printing is mentioned. And if you want a quick, simple stamp (say, for a repeating design), you can actually cut a potato in half, carve your design on the raw face and dry it with a paper towel. And be sure to use water based ink *only* :)
Jul 1, 2010. 3:32 PMTallTrav says:
Lino prints are great! Thanks for placing it here and showing how simple it is to make something pretty and useful. Great job!
Jul 1, 2010. 8:54 AMjnifrwebb says:
I LOVE this. I bought a set of carving tools because I have read you can do this on erasers. When I get a little practice in, I may be back to ask a few questions.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
43
Author:trucdart(ArtProject2010)
Hi, I'm Marianne Bland, an artist & crafter in Northern California. Last year I finished Art Project 2010, a self-imposed challenge to create at least one new piece of art every day for a year. I publ...
more »
