3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How I Rack-mounted my Line 6 Pod Guitar Effects Processor
Step 7The LEDs and 7-Segment display
The original Pod had used red LEDs and a red 7 segment display - for a bit of my own flavor, I used all green instead...
From the AutoCAD drawings, I had cut out a piece of breadboard to mount all the components on and the first thing I did was to solder the wires onto the new indicators. Each of these wires would eventually be soldered onto the appropriate place on the original PCB where I removed the original component...
When the back-side of the indicator breadboard was complete, I soldered on (directly to the PCB) wires for the push-button switch connections - after soldering each connection, I tacked down the wire with some hot glue to make sure it didn't shift.... (one note though - in the end, my connections for the push-buttons failed somewhere, so none of the push-buttons work - which is OK, because I control everything via MIDI anyhow... but if you want your buttons to work, use caution here!)
And then finally - the connections from the indicator breadboard was soldered onto the PCB... now that's starting to look like a mess of wires... At this point, I mounted the PCB in the rack frame to make it easier to work on...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:djhoy
