3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How I built a Solar iPhone Charger for under $50.
To see my personal site with these tutorials and news, please visit http://www.BrennanZelener.com
**DISCLAIMER**
I am not responsible for any damage that you may cause to your iPhone or any device that you use with this charger. I can not stress the importance of checking your circuits with a multimeter enough, and I can assure you that I've done so at every step in this build process. Your phone is a very expensive device. Treat it like one!
Intro and Design:
Over the past month or so, I've been working on designs for a stationary solar iPhone charger. By stationary I mean a charger that will be kept in a fairly permanent place. I bring mine with me if I'm going to be camping or staying somewhere for a while, but it's really not meant to be portable.
This isn't only a solar iPhone charger. You can use it with any device that will charge via USB. I just happen to use it to charge my iPhone. Also, this design doesn't include a battery in the circuit - which means that you'll have to charge your iPhone when the sun is out and shining. I know it's a serious inconvenience, but adding a battery makes the circuit much more complex - and is a bit more costly. I'll be following up this design with an update on how to add a battery conveniently into this circuit.
The idea behind this panel is that it's simple (and cheap!). You don't have to have any prior circuit knowledge,or familiarity with electronics. I'm really just stepping out of the novice stage as far as soldering is concerned, so this is a great beginner project for just about anyone!
Step 1Tools and Materials
Tools and Materials
As I say in the title, I built this charger for just a bit less than $50. That doesn't include the cost for tools and a few of the materials that were salvaged, but if you spend enough time on eBay you should be able to build yours for the same amount, if not less.
Let's take a look at what was used to build the panel.
Tools:
Soldering Iron w/ Solder and Flux
Needle Nose Pliers
Wire Cutters/Stripper
MultiMeter (IMPORTANT)
Materials and Prices:
Part/Material ------------------------------------- Source ----------------- Cost
10 Watt Solar Panel ----------------------------- eBay -------------------$41.45 w/ shipping
7805 5Volt Regulator ---------------------- RadioShack ------------- $1.59
iPhone/iPod Cable ------------------------------ eBay ------------------ $1.20
USB Extension Cable -------------------------- eBay ------------------ $3.00 w/ shipping
Red/Black small-guage wire --------------- On Hand --------------- Free
Electrical Tape --------------------------------- On Hand --------------- Free
Small Zip Tie ----------------------------------- On Hand --------------- Free
60 comments
1-40 of 60next »
Mar 6, 2012. 7:20 AMASCAS says:
The 7805 only limits the regulated power supply by 1 ampere, probably this wouldn't work with the iPhone 4S nor the iPad. But it's a good guide though :)))
Feb 22, 2012. 4:52 PMgarren11 says:
Im planning on downsizing this and including a battery for it. My concern is what would be the chance of it potentially short circuiting the iphone if there is any chance at all. All help is appreciated.
Sep 22, 2009. 1:07 PMAsmodeo says:
Nice instructable!
I was thinking about something like this to recharge my cellular phone....
The regulator goes "hot" because the formula to calculate the disipated power is:
P=(Vin - Vout) / Iout
In your circuit:
P = (20v - 5v) / 0.5A = 15v / 0.5A = 30Watts!!!
Go get a heathsink for your poor regulator!
You possibly could use a 12V solar panel, with 0.5 Amperes output current, and the dissipated power would be
( 12v - 5v ) / 0.5A = 14W ...still in need of a heathsink...
I don't know if there are 9v solar panels.....
Dec 12, 2011. 4:43 AMsolaralternatives says:
Wrong. P=IE, not P=I/E, so P out(max) is 7.5W
Sep 24, 2009. 7:22 AMbananafred says:
Just so you know, 15v at 0.5A is 7.5W, not 30. You multiply, not divide.
Sep 24, 2009. 12:52 PMAsmodeo says:
OUCH! YES, you´r right!!! but....I made you think. huh!
Sep 24, 2009. 2:22 PMDraakUSA says:
You should have spotted that since it's only a 10W solar panel. ;-)
Nov 20, 2010. 9:48 PMlloydrmc says:
Darn, I thought that he had cold fusion or something going there.
Sep 22, 2009. 4:12 PMctfjustice says:
Sorry, I forgot to mention that it has several different settings for different voltages. They are as follows, 3, 6, 9, 12 volt configurations. I got it just to tinker with, works pretty well for my purpose and curiousity.
Sep 22, 2009. 4:10 PMctfjustice says:
Hello Asmodeo, just a quick little blurp about you wondering if there were any 9 volt solar panels out there. Harbour Freight sells a neat little solar charger with battery power as well for around $12, not bad.
Sep 22, 2009. 7:33 PMDarkStarPDX says:
Yo! I just picked up the "1.5 Watt Solar Panel w/Auto Lighter Adaptor" from a Harbor Freight store for $14.99. My plan is to build a USB charger as well, however I'm going to desulfate a 12 volt hobby battery (7 amp hour) and use that to capture the daytime sun, and then charge my USB devices at night.
After I make my prototype, hopefully I'll buy another to put together an instructable, but a sneak preview includes me using 5 volt switching regulators instead of 7805's (linear regulators). You can get the switching regulators from Dimension Engineering. Another problem I need to work around is moving the solar panel "smarts" from the "auto lighter adapter" to the inside of the actual solar panel.
Lookin' great, keep it up!
Nov 20, 2010. 9:49 PMlloydrmc says:
Mouser.com has the Murata switch mode regulator
Oct 11, 2011. 1:33 PMmonkyDJ says:
Do you need more then 10 w???
Oct 6, 2011. 12:32 PMmonkyDJ says:
I hope this works man, because I doing this for a project and I need to get a good mark!!! lolz
Sep 1, 2011. 8:17 AMginbot86 says:
Instead of a linear regulator, you could pick up a switched-mode PTH08080W from Texas Instruments. They offer sample parts free of charge, and even shipping is free. These offer over 2 amps of current compared to one of the linear regulators, and is adjustable with a simple potentiometer.
http://www.ti.com/product/pth08080w
Jul 10, 2011. 8:33 AMpeppero says:
i have a problem my phone not charge but discharge and the same for the mp3 player how it's possible?
May 19, 2011. 7:23 AMsdobbie says:
There is a much quicker way to do this. If you got a usb car charger and connected it to the solar panel you would have a more efficient charger. Car chargers accept voltages from 12 to 24 volts usually.
Sep 22, 2009. 3:41 PMPhoenixmill says:
What works for some good low voltage Solar panels are the Garden lamps that people use to line their driveway. you can ghetto rig those together to get really low voltages, or really high ones. you would be surprised at how many people have broken garden lamps they are willing to get rid of.
Apr 1, 2011. 3:47 PMSchooniedude says:
if you decieded to use one of those, would you need the same parts and everything?
Nov 20, 2010. 9:53 PMlloydrmc says:
Good idea!
Sep 24, 2009. 3:47 PMReCreate says:
I recommend you strap the Voltage regulator to something, It may overheat while the i-phone sucks electricity through it. Though they do have thermal shutdown to prevent them from burning themselves up.
Nov 20, 2010. 9:47 PMlloydrmc says:
7805s do indeed have heat overload circuitry, as do, no doubt the murata switching version that's a drop-in replacement.
Apr 9, 2010. 1:19 PMbutterflypoo says:
This seems awesome! I am not sure if someone already mentioned this in the comments, but isn't it bad for electronics to be exposed to too much light? Someone told me that once and you can even read it on the back of the packaging. Simple solution: cover up that iphone with an empty dark container (as house to keep it cool)?
I am gonna try tackling this project this summer!
Nov 20, 2010. 9:46 PMlloydrmc says:
Uhh - if I wanted to keep something cool outdoors, I might use something white or even reflective.
Apr 25, 2010. 7:15 AMkrimb1 says:
 What a great guide! Really sturdy, and the built-in blocking diode is really awesome.
One question though: this setup won't trickle charge the iPhone after it's fully charged, right?
Nov 20, 2010. 9:43 PMlloydrmc says:
I seriously doubt that an iPhone counts on the charger to do anything. The charge circuitry is going to be in the phone.
May 17, 2010. 12:29 AMlloydrmc says:
Try the Murata 78SR regulator.  It's a drop-in replacement for the 7805, except that it's switch mode, can handle two amps, and is much more efficient than the linear mode 7805, to the point that it doesn't even need a heat sink.  I wouldn't sweat the higher current - the unit will draw what it needs.  I would do the resistor hack, though.
Sep 20, 2010. 12:49 PMjackzylkin says:
WOw I never heard of that part -- sounds great
Nov 20, 2010. 9:39 PMlloydrmc says:
It's not even expensive. Try Mouser.com
May 8, 2010. 1:55 PMsenor taco says:
For some reason my iPhone won't charge from this. I tested all the connections, and everything should be working, but when i plug my phone in nothing happens...
Oct 9, 2010. 9:57 PMAdam Manick says:
Once again, build this circuit.
Sep 24, 2009. 7:59 AMdizingof says:
Are you sure it's charging your iphone? :) A simple usb connection wont do it for the iphone, you need to add 2 resistors to the D- and D+ of the usb connector to let the iphone "know" it can start accepting current and start charging.. Note this, an icon for a REAL charging status is a small lighting and not a 'concected to usb' icon... google for more info on how to charge an iphone using USB . Good job!
Oct 9, 2010. 9:56 PMAdam Manick says:
It is not actually charging his Iphone. For it to charge he needs to build this circuit.
May 23, 2010. 10:42 AMmatroska says:
 +1 on this comment. Apple stuff (and other picky devices) really need the USB signal in order to charge. (Hm, since yours charged anyway, it's not an absolute requirement I guess...)
For more info about this (or how to make your picky device charge with your custom charger) check out this instructable:
www.instructables.com/id/How-to-get-your-iPod-to-charge-with-your-homemade-/
May 8, 2010. 3:04 PMsenor taco says:
Could you be a little more specific about those resistors? I think that is the problem I'm having with my charger, so if you could help me out that would be great.
Sep 27, 2009. 11:41 AMJohenix says:
Cheap (perhaps even free) solar panels can be obtained at your local Volkswagen dealer. The panels are plugged into the cigarette lighter socket of cars in transit to keep the battery charged. They produce 12 volts at a few miliamps and have suction cups for attaching to the inside of a window. Or look for VW Solar on EBay.
1-40 of 60next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:akbrennan(Personal Blog)
My name is Brennan and I'm a Computer Engineering undergraduate at Colorado State University. I'm very tech oriented, but I am a serious outdoors kid. The combination of the two has developed a passi...
more »
