After years of riding, the frame is still okay and I am still alive too, although I prefer riding my bike equipped by the bamboo/carbon frame, which I have built using the same method described here. Until now, several frames have been built by this method in the world.
Remove these ads by
Signing UpStep 1Few important things you need for building the carbon frame
2. Metal parts - they include an aluminum bottom bracket shell, head tube, short seat tube, cable stops, rear dropouts and a rear brake bosses. The used thin walled tubes and cable stops were made on a lathe, for the carbon frame I have purchased rear dropouts and brake bosses from the bike parts supplier. I have made them by water-jet cutting for the bamboo frame. I prefer to use 7075 Alloy for the metal parts. It is good to have all aluminum parts anodized, as then you do not need to wrap a light layer of fiberglass around the aluminum tubes and part of the rear dropouts as an insulation between the aluminum and the carbon against galvanic corrosion.
3. Foam core - I have used polystyrene foam to make the core of the carbon frame. But it is better to use extruded polystyrene, or polyurethane foam, which is more rigid. Later I have used the polyurethane foam which is normally used for insulation of the outer walls of buildings.
4. Materials for laminating - I have chosen a bi-directional woven carbon cloth (180 grams per square meter). I have used MGS's L285 epoxy resin with hardener 285 for laminating. For the carbon frame I used about 3.8 sq.m of the fabric, for the bamboo frame about 2.0 sq.m. You can also use uni-directional carbon for the base layers and use the bi-directional carbon just for the outer layer.
5. Supplies - I used plastic kitchen foil for covering the workbench during the wetting out the carbon, latex gloves, a small digital scale for weighing of the exact volume of resin and hardener, cups for mixing, paint brushes for wetting out, lots of electrical tape, sand paper and a good respirator during sanding.
6. Patience - the more the better
Harley Fenders
Carbon Fiber Bicycles , Carbon Wheel Sets
Definitely on my list of things to do when I get some time/space/money etc etc...
forum
just google polystyrene solvent (or whatever type of foam you used) then double-check to make sure that it won't eat your epoxy, too
please respond
thanks and great build i hope to build one someday
and how much was the total build cost
thanks again
Then there are several processes to laminate it, the one what Brano described is a very effective and cheap solution. If you plan to apply carbon fiber (or glass fiber, or texalium) texture on a surface, you may do the same punch-made-holes method on 0.2-0.5 mm thick film, and then somehow pull it on the treated surface.
Was just wondering how much CF cloth you needed to make the full frame? and what you used as a template for the bottom bracket shell and head tube?
Cheers,
Mike
