Step 2Making the core
I had polystyrene foam rods of the necessary diameters, made simply by using hot wire foam cutter. The cross sections of the main rods was circular, the chain stay and the seat stay were elliptical. I have wrapped these rods with one light layer of fiberglass to increase their rigidity.
In this picture you can see the aluminum parts in their exact position. The polystyrene top tube and down tube is already bonded with carved small pieces of polystyrene for the next sanding. In the front of the picture on the ground the chain stay was being prepared for sanding (to achieve proper shape) and bonding.
Check http://www.instructables.com/id/Hot-wire-foam-cutter/ , http://www.instructables.com/id/Make-a-CNC-Hot-Wire-Foam-Cutter-from-parts-availab/ , http://www.instructables.com/id/Hot-Wire-Foamcutter-Battery-Powered/
