How I built a carbon bike frame at home (and a bamboo frame too)
Step 3Making the core 2
Making the core 2
After adding all of the polystyrene rods I have sanded all of the added small parts in the places of rods connection areas to achieve soft shapes. After that I have wrapped these junctions with one light layer of fiberglass. After the curing of the epoxy resin, I have softly sanded the whole surface.
After finishing the frame, you can melt the polystyrene out of the frame by using acetone, so you can save about 90 g of the weight. I didn't do so, as I think the core helps to dampen the vibrations and shocks.
2 comments
Aug 10, 2011. 8:10 PMiluvcamaros says:
Did you do anything special to the legs of the dropouts to create a better bond with the CF?
Jul 15, 2010. 2:36 PMbhale1987 says:
Where did you get the foam rods?
Aug 11, 2010. 10:30 PMZeroTruths says:
He made them by using foam blocks and cutting it with a hot wire foam cutter.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
54
Author:Brano
