3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How I built an electricity producing wind turbine
Several years ago I bought some remote property in Arizona. I am an astronomer and wanted a place to practice my hobby far away from the terrible light pollution found near cities of any real size. I found a great piece of property. The problem is, it's so remote that there is no electric service available. That's not really a problem. No electricity equals no light pollution. However, it would be nice to have at least a little electricity, since so much of life in the 21st century is dependent on it.
One thing I noticed right away about my property is that most of the time, the wind is blowing. Almost from the moment I bought it, I had the idea of putting up a wind turbine and making some electricity, and later adding some solar panels. This is the story of how I did it. Not with an expensive, store-bought turbine, but with a home-built one that cost hardly anything. If you have some fabricating skills and some electronic know-how, you can build one too.
More details on this project and my other alternative energy projects including my home-built solar panels, and my home-built biomass gasifier can be found on my web site.
Step 1Acquiring a generator
I started by Googling for information on home-built wind turbines. There are a lot of them out there in an amazing variety of designs and complexities. All of them had five things in common though:
1. A generator
2. Blades
3. A mounting that keeps it turned into the wind
4. A tower to get it up into the wind
5. Batteries and an electronic control system
I reduced the project to just five little systems. If attacked one at a time, the project didn't seem too terribly difficult. I decided to start with the generator. My online research showed that a lot of people were building their own generators. That seemed a bit too complicated, at least for a first effort. Others were using surplus permanent magnet DC motors as generators in their projects. This looked like a simpler way to go. So I began looking into what motors were best for the job.
A lot of people seemed to like to use old computer tape drive motors (surplus relics from the days when computers had big reel to reel tape drives). The best apparently are a couple of models of motor made by Ametek. The best motor made by Ametek is a 99 volt DC motor that works great as a generator. Unfortunately, they are almost impossible to locate these days. There are a lot of other Ametek motors around though. A couple of their other models make decent generators and can still be found on places like Ebay. This web site talks about the virtues and vices of various Ametek motors when used as generators. http://www.tlgwindpower.com/ametek.htm
I managed to score one of the good 30 volt Ametek motors off of Ebay for only $26. They don't go that cheap these days. People are catching on to the fact that they make great wind generators. Other brands will work, so don't fret about the price Ameteks are going for. Shop wisely. Anyway, The motor I got was in good shape and worked great. Even just giving the shaft a quick turn with my fingers would light a 12 volt bulb quite brightly. I gave it a real test by chucking it up in my drill press and connecting it to a dummy load. It works great as a generator, putting out easily a couple hundred Watts with this setup. I knew then that if I could make a decent set of blades to drive it, it would produce plenty of power.
There is more information on how to choose a motor for use as a generator on my web site at http://www.mdpub.com/Wind_Turbine/
301 comments
1-40 of 301next »
May 11, 2012. 12:43 PMmcronnie says:
For an extra power source during calm weather, could you cover the blades/tail in solar panels?? :)
May 13, 2012. 12:17 PMseraine says:
You probably could, but they wouldn't really be worth it. For one thing, most cheap solar panels are flat, which doesn't work for catching the wind. For another, if you put leads on the solar panels, they would become tangled and cut really fast. Also, when they are placed vertically (such as on a blade), they catch sunlight for only a short period of time. In fact, the extra weight on the blades would probably lessen the power produced. You would be much better off by putting them on a flat surface or in a panel.
Apr 26, 2012. 8:03 PMTheGreatS says:
Here is an easy yes or no question. Will the char controller work for any motor of any voltage rating? Mine is a 120 volt DC motor salvaged from a blender (If that helps any).
Apr 14, 2012. 1:00 AMacicalla says:
I have a question regarding the 99v ametek motor and charge controllers. So far I have only been able to find charge controllers that accept 12, 24 and 48v dc as input from either a wind turbine or solar panel. So what if anything needs to be done to step down the voltage from 99v to 48v dc to the charge controller? Or do I even need to change anything? Can I just wire the 99v ametek dc output to the 48v charge controller?
Apr 11, 2012. 2:19 PMMOMJE9 says:
i can used motro ca,?
Apr 6, 2012. 8:01 AMLIS10114344 says:
hi i can get hold of a pillar drill easily, it is rated 1420 rpm and 240 volts,
so 1420 divided by 240 =5.92 rpm - per volt
would this be a good motor/generator for a wind turbine?
Mar 30, 2012. 12:52 PMLIS10114344 says:
hi just wondering, if a motor is producing a DC current to charge a battery then is there any need for a rectifier/bridge rectifier to stop the charge from the battery reverting to powering the motor?
thanks.
Mar 22, 2012. 9:34 AMDa Person who plays paintball. says:
Great idea, great project, great description, great everything.
Although, a little idea popped into my head, if you could make turbines with inbuilt solar panels, would that increase the power available.
Her`s a great `ible for DIY scrap solar panels.
http://www.instructables.com/id/DIY-Solar-Panel/
Mar 1, 2012. 9:10 AMharveylo says:
The drive (propeller) is an important part of this project. I made a two bladed prop of mahogany, light and easily worked. I was on my sailboat at the time so shaping the airfoil was less than exact. I could balance it statically but not dynamically very well. The airfoil shape is a must if you want to have it work. The airfoil pulls the propellar around. The outer third of the blade produces 2/3rds of the power so I've read. Also there are companies that make blades but that's no fun. I have a car generator which if I don't decide to play some more will be available.
I used a diode to prevent the battery from driving the blade. Because of the inaccesability to reach it on the boat, I bypassed it to start the blade turning in light breezes and it would then continue to generate. When at anchor on a boat the boat usually heads into the wind unless you have strong tides.
Dec 31, 2011. 6:44 PMedvannatta68 says:
hi! how are you want can get information this you build me hear or at wolfthunder68@yahoo.com or espiritwild09@aol.com
Dec 20, 2011. 7:42 PMshadow68 says:
want know get more information on this hope help me OK?
Nov 29, 2011. 8:23 AMnbwriter says:
The Mdavis WindTubine Tutorial is by far the best practical build I've seen online. Thankyou for posting!
Finding a solution for blade propellers that's both durable and efficient amounts to a fascinating engineering challenge. From my research, PVC blades (while cheap and easy to make) do not have the basic strength necessary to survive high wind speeds. (As Mdavis discovered).
Curiously, commericially made blades (for HAWT turbines) do feature connecting "tabs" that are placed centrally, rather than at the sides. Two main differences are apparent:
1. Carbon fibre is favoured over PVC as the blade material
2. A lamination process is used during blade manufacture (possibly strengthening the finished blade propellers and tabs).
Aerodynamically, the blades need to bulge at one side, then taper at the other. (A basic aerofoil). This reduces drag, as does a cambered blade. Since lift is produced once your aerofoil blade is in operation, this must be a contributory factor leading to blade failure (because the turbine is literally trying to "take off"!)
Personally, I think this "take off" factor amounts to a design flaw in HAWT turbines, since the primary objective is to capture wind energy and transfer it to the DC motor. I'd like to do testing on VAWT systems (Savonius) to see if the "lift" problem is minimized.
It's unlikely any comparison data (between HAWT propeller and VAWT savonius efficiency) exists. But you never know, the Internet is a big place... Any feedback welcomed.
NB
Nov 17, 2011. 1:28 AMpantaz says:
The charge controller has been redesigned by the original designer. Reduced part count, and easier to find components!
http://www.mdpub.com/555Controller
 He also has kits and assembled units available (see link on his website).
Nov 13, 2011. 9:34 PMsbob1 says:
why not choose dynamo?
Oct 19, 2011. 11:19 AMBarrettkg says:
I have the chance to buy a 1/2 hp motor. The specs are: Voltage is 115/230. rpm 1725. I am waiting to hear back on the amperage. Would this be a decent motor to use?
I know the rpm is really high but I was wondering if the high Voltage would make up for it.
Thanks for the help
Oct 18, 2011. 9:43 AMWV_Kokamo_Joe says:
I have a 1000 watt generator and the engine leaks oil when it is started or running. I was thinking of removing the generator portion and using it with some sort of a turbine setup.
I have not thoroughly inspected the current setup on this generator and do not know if it is a DC or AC generator although it has ports for accessing DC along with the AC outlets.
How hard would it be to utilize everything already included in the parts on this generator?
Jul 14, 2011. 10:37 PMspylock says:
I have a question,I was going to try to make one with a 12 volt power wheels motor,I plan to use a charge control,but whats going to keep my battery from running the moter,the control?How will I solve that problem ?Ive herd reverseing the motor wires,but dont understand.
Jul 31, 2011. 1:30 PMA flyin muffin says:
Read the first paragraph on step 8. The blocking diode.
Jul 31, 2011. 10:24 PMspylock says:
Wil that be true if I happen to get hold of one of the old computer moters,I forget the name of them at the moment but Im sure you know the one Im talking about,Ive seen other sites that says the diode isnt needed with those.Thanks and Im sorry to keep bothering you.
Sep 18, 2011. 1:06 AMTobita says:
CRT monitor?
Sep 8, 2011. 10:02 PMrtaznita says:
can i use 60 v ametek motor?
Aug 15, 2011. 9:58 AMitri45 says:
could i use an old 6 inch fan motor as a generator.
great job on the generator.
Feb 7, 2010. 8:49 PMjchowarth says:
won't the wires twist up inside the tower over time?
Jun 19, 2011. 2:33 PMGrapeApe226 says:
Well your vacuum cleaner cord winds up over time and you have to pull it out and unwind it. It's not that hard to unplug your long extension cord from the charger end and give it a few twists in the needed direction. I live in an area where the wind blows180 degrees from morning to evening; about 30 miles inland from the Pacific Ocean. This is something I will keep an eye on,
Jul 14, 2011. 10:29 PMspylock says:
You can pu a stop on the turbine so it wont spin all the way around,it will go as far as the stop both ways though still allowing the turbine the full 180.
Jun 13, 2011. 4:43 AMOle bally says:
HI There, I live in a country where we cannot just send funds outta the country...(a dictatorship) so very sadly I can't become a Pro Member!
Have you or would you please have a look at the Henry Moray website and the Tesla website. Both these guys were pioneers in the energy field and a Tesla generator offers FREE electricity! Apparently from the 'cosmic' energy field!
I'd love one of the members to get one of the kits offered, build it and then give us all the heads up as to it's reality!
May 20, 2011. 3:21 AMBuildHomeSolarPanel says:
Great videos there. It is very informative and persuasive. Thats a great way to build a wind turbine. It could give you a lot of benefits and advantages.
Keep it up. Great post too.
May 11, 2011. 5:58 AMTushar Max says:
When i see the picture showing the the aluminum plate, toothed pulley and the blades assembly, it set me thinking "could one not use a similar looking ceiling fan assembly"?
May 3, 2011. 8:10 AMSciniro says:
Great work, compliment. Bravo
Apr 27, 2011. 2:42 AMvignesh1230 says:
Dosent he wires get tangles by turning around and around and arund by the wind? I know a slip ring works but, any easier methods?
Mar 13, 2011. 9:50 PMjlund says:
K so I'm just a kid with out a 1,000,000,000,000 dollars and what to run an old fan motor as a wind turbine attached to my roof with power cables coming through my window to power my clock and charg my iPad I have it drawn out in my head I just need some help of how I get it rotating and producing power I have no clue how to set this up to make power plz help
Apr 25, 2011. 2:22 PMoanderson says:
Your just a kid who doesn't have 1000000000000 dollars, but you still have money to burn on an Ipad :)
Mar 17, 2011. 8:47 PMryandean98 says:
You really can't use a fan motor because it has no magnets in it.
Apr 5, 2011. 6:43 PMrocket master says:
does it now? (all electric motors require magnets to work)
Apr 21, 2011. 8:54 AMkilofeenix says:
AC motors dont have magnets, pull apart an old box fan and see if it is magnetic, it isn't. What you could do kid, is go to radio shack and buy some magnet wire also called enameled wire and make your own DC motor, take apart an old 80mm computer fan and look inside, that is basically what you will be building. The only other thing is to get your parents to buy you some neodymium magnets off ebay. then look at this instructable on how to put it all together.
http://www.instructables.com/id/DIY-1000-watt-wind-turbine/
It's not as hard as it looks and you dont need all that resin to hold everything in place, especially if you get the counter sunk neodymium magnets that you and screw onto a piece of wood, obviously your not trying to power your house but this instructable will tell you how it works and how to build one from scratch. hope this helps
Apr 22, 2011. 3:00 AMvignesh1230 says:
can i use a 250Watt scooter motor?
Apr 21, 2011. 11:41 AMdiogo monteiro says:
Dear Friend I read your article and imediatly went to my old motors box. I knew I had a couple of those AMETEK motors, they came from I don't know what I save from the trash I saw on the street, I hooked up a 12volt led bulb to it and just with a hand spin with the shaft , it almost burned the bulb, so I decided to do your project, I will post pictures as soon as I have something done
Great Project
Thanks
Diogo Monteiro
Apr 20, 2011. 11:50 AMkilofeenix says:
Will any DC motor work as a generator? I'm not even trying to build something that can power my house, I'm just ding this as a weekend project type of thing. Small Small scale.
I have an old DC motor out of an electric airsoft gun hook it up to a rectifier and nothing happens, on the other hand i took an old 80mm computer fan hooked it up to the rectifier gave it a nice spin and it lights an LED, so why isn't the bigger DC motor producing any electricity?
Feb 26, 2011. 12:00 PMaustinpowerzzzzz says:
im planning on building a tree hiouse. and i think htis would be perfect for suplieing electricity for it. is there any way i could convert the electricity coming fromt he turbine into an electric outlet? if anyone oculd hlep that would be sweet.
1-40 of 301next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
265
Author:mdavis19
