3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How I fixed my wireless adapter
  • last photo ←
My Belkin FD6050 started failing for no apparent reason. After changing drivers in Linux and Windows I found out it was a faulty cable very near it's connector. The only way to fix it was changint the entire cable with something else. Something like USB A to A extension cord.
Step 1Diagnosing the problem
I had to find the problem with my wireless adapter. It was about 5cm (2 inch) away from connector in a form of torn cable. As you can see the black wire was torn out of the plastic molded connector.
4 comments
Nov 15, 2006. 1:19 PMJakeTobak says:
Did you not solder those wires? Also, you may want to try some heat-shrink tubes for the wires. The reason I like to use heat-shrink tubing more than anything else is that it's very fun to use, except when you solder a wire together and realize that you haven't put the tubing on yet and have to cut and solder the cable again.
Nov 16, 2006. 12:53 AMFake_Name says:
The thing that insulates wires is called insulation, not isolation...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:necromncr
