3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How I made a knife
How I made a knife
  • last photo ←
This is a Photo diary of a knife I made today.
This is my first knife and my choice of design was limited to the size of good scrap steel I had in my shed. I will probibly use it in the kitchen for meat and cooking while camping.
The steel is a old 7' saw blade that I had lying around. I t was a bit small so I had to cut the shape out of 2 pieces and weld them together. This is a full tang knife and the timber still needs to be treated.
One mor thing it cost me $0. Just gas and sandpaper that I had the rest is recycled and re-used.
8 comments
May 24, 2012. 5:25 PMIronwolfcanada says:
Great effort for a first knife!
I've made a few from scratch (stock removal),
but have been designing them & customizing them for a long time.
Yours is a good functional design.
I'd suggest having a look at Wayne Goddard's book
$50 Knife Shop; it's loaded with great ideas for building forges on the cheap!
Keep up the good work.
Oct 14, 2011. 10:36 PMbobthebuilder728 says:
Nice knife! I make them from old saw blades too, take a look at mine
Aug 17, 2011. 4:28 PM67vj says:
Great Job. If you need supplies or materials for knifemaking try Jantz Supply
knifemaking.com
Aug 1, 2011. 12:29 PMflamesami says:
how do you power that forge? is it charcoal, gas or electric? I reallylike your knife, way better then my first one (though it probably doesn't count- the ones I heat-treated don't have/need handles and the one i handled I just shaped a bit... Did you normalize the steel before heat-treating it, or did you anneal the steel before you worked it?
Aug 9, 2011. 3:44 PMflamesami says:
yup! that's annealing (bring piece to red hot, let cool), it's important if you've put stress on it during making (used power tools/forged) cos it releases tension and avoids microfractures that weken the structure and can make it crack when quenched
Aug 12, 2011. 1:29 PMflamesami says:
as far as I can remember right now, the routine is anneal(bring to red hot and let cool in ash/vermiculite), shape, then normalise (heat to red, then let cool overnight (aligned north-south if you feel like it)), quench and temper, then sharpen and put a handle on it ... (please note that this is what I've read and I'm not qualified in any way)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:HanzieO
I am a electrician/fitter that install, commission and test new Escalators. I only have a tiny shed to create my inventions in.
