loading
Here is my step by step tutorial on how to make my threadcake entry.
Don't forget, I am competing once again to represent Portland in New York on the hit TLC show, The Next Great Baker! The final spot on the show is determined solely by votes so getting the support of my fellow cake lovers is key! This is where you come in! Vote for me and help send me to NYC in two weeks to compete against 12 other bakers for the grand prize of $100,000!!!
I really think I can bring some good caking to this show without the catty drama. I really want to make it on for my talent not my "bitchy" personality like some other contestants. I really want this chance so bad to open a bakery in my community and bring the FIRST 3D and sculpted cakes bakery to Portland.
Here is the link to vote http://tinyurl.com/lizmarek you can vote every day!
When I win, I plan to use the winnings to open the most kick ass bakery PDX has ever seen!
I would be happy to talk on the phone, or just email any information you need!
Thank you so much for your support!
Liz Marek
www.artisancakecompany.com
Step 1: Bake the Cakes!
I baked 3 full sheet cakes for this project. I used a vanilla butter cake recipe but pound cake or any other dense cake would work great.  It also helps if you let the cakes sit overnight (wrapped in plastic wrap) so they are not as fragile when you need to start sculpting.
*Note: This is not really a beginner tutorial. I am assuming you know how to bake a cake, what fondant is, buttercream etc.
Step 2: Make the Stand
To make the stand, cover a 12" wooden cake board with cake foil. Attach a 1/2" floor flange with screws then a 1/2" PVC adapter to hold your 1/2" PVC pipe. Use PVC cutters to cut the pipe down to 18". This will ensure your cake doesn't fall over.
Step 3: Start Stacking the Cake
I started cutting pieces of cake off the main sheet cakes and stacking them onto the structure. I used white chocolate ganache as my filling so that it would be strong and tasty! Every few layers, I cut a piece of cardboard to support the next few layers. Support your cardboard with straws or dowels so the bottom layers do not get crushed by the weight of the cake on top.
Vote Elizabeth Marek for Next Great Baker!  http://tinyurl.com/lizmarek! August 19th at Midnight is when voting ends!
Once all the layers have been stacked and carved, I covered the whole cake in buttercream and put it in the fridge over night to chill before covering in fondant. *note, I had to take pretty much all the shelves out of my fridge to get the cake to fit.
Step 4: Sculpting the Face
I used white modeling chocolate to sculpt the face. You can look up a recipe or use mine. Add 4 oz of warmed karo syrup to 8 oz of white melted chocolate (good quality, not melties)
Vote Elizabeth Marek for Next Great Baker!  http://tinyurl.com/lizmarek ! August 19th at Midnight is when voting ends!
The modeling chocolate takes a few hours to set up so you might make this ahead of time while the cake is cooling in the fridge.
I applied a layer of modeling chocolate all over the face area then slowly built up the features like the nose, lips, eyes and ears. This will take a lot of time depending on how good of a sculpter you are so be patient!
Step 5: Make the Bird
To make the bird, I used lollipop sticks and gumpaste. I made the body and then attached the wings. This is another thing you should make a head of time.
Vote Elizabeth Marek for Next Great Baker!  http://tinyurl.com/lizmarek August 19th at Midnight is when voting ends!
I made each feather individually and used a sculpting tool to give dimension to the feathers. After the bird was dry, I rubbed some dark blue food color into the detail of the winds and then wiped away the excess with a damp paper towel.
Step 6: Painting the Eyes
To create the eyes you will need oil based food coloring for tinting chocolate candies.
Regular food color will bead up and not blend since it is water based and chocolate is oil based
I used a large piping tip to put an indentation where the iris will be. I filled in the iris with dark blue at the top and lighter blue at the bottom. This creates a realistic gradient.
I filled the pupil in with black food color as well as around the edges. I used a dab of white food coloring (water based) to add a little highlight to the pupil. Lastly you use more modeling chocolate to create the upper and lower lids.
Use more food color for eyelashes, eye shadow and eyebrows.
I also used a little blue mixed with vegetable oil to tint the lips
Step 7: Adding Hair
To make the hair, you will apply strips in layers
Roll out a strip of fondant, create texture with your fondant tool and apply in layers using a little gum glue (water mixed with tylose powder)
I used some plastic wrap to keep the bangs off her face until the hair set up a little
Step 8: Adding Ruffles
To add the ruffles, the concept is similar to the hair.
I rolled out long strips of blue fondant (I varied the darkness of blue as well) and ruffled the edge using a ball tool and flower sponge.
Apply in strips with gum glue
As you can see, I inserted dowels into the shoulder areas to support the longer pieces of fondant.
I also added our little bird friend during this step
In the front, I made an area to suppor the sugar flower by inserting a long popcicle stick into the chest and bending it. I molded a piece of fondant around the end to support the finished sugar flower. I also created some buds with flower wire and fondant
Step 9: Adding Sugar Flowers
To make the sugar flowers, watch my tutorial on youtube
<object width="480" height="360"><param name="movie" value="http://www.youtube.com/v/yqjACH2Rc7c?version=3&amp;hl=en_US&amp;rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/yqjACH2Rc7c?version=3&amp;hl=en_US&amp;rel=0" type="application/x-shockwave-flash" width="480" height="360" allowscriptaccess="always" allowfullscreen="true"></embed></object>
Step 10: Eat and Enjoy!
If you enjoyed this tutorial, please vote for me to show my skills on TLC's Next Great Baker where I will compete against 12 other bakers for the grand prize of 100k! I plan on using the prize money to open my own bakery!
You can read more about my story on my website
Thank you for enjoying this tutorial!
I would've voted for you for sure! This is an absolutely breathtaking piece of art....you're beyond talented!
<p>This took lots. Of. Time. Not like to scare folks off, but DANG. Increds. Thanks for sharing. I want to make a Avengers Hulk cake now! RAWR~1!</p>
that should be a smiley but it got a ? it should mean :/
and sry for the bad grammar ?
thanks a lot for this instruction it is amazing I thried it but mine was terrible I had some problems with the cake it broke a lot and I`m not as a pro than you (I tried sheldon from the big bang theory) ☺
i think my heart just stopped. <br> <br>you really need to put a &quot;WARNING: graphic content&quot; on that image.... *sob*
&quot;strong and tasty&quot;.... you don't... you don't mean, like, EAT it!? actually take a knife and... and.... i can't say it. what is WRONG with you!!!!?
Amazingly beautiful edible work of art!!!!!!
excelente te quedo, eres una artista, tienes que seguir en esto y se que te va a ir muy bien, bendiciones. HECTOR BARRIENTOS DE CHILE
NO! NO! NO! NO! NO! How can you do that to her! I was gonna marry her! You are criminal! I curse you! <br>Ahem! Ahem! (sanity returns) <br>Awesome! beautiful! Brilliant!
O...M...G... thats not a cake, thats devine!
You are truly amazing, Very impressed.
Wow, it's... it's... you're amazing! Great job!
Amazing! The colors are gorgeous and you are obviously extremely talented. I hope you get your shop!
This is the most beautiful cake I have ever seen! The link went to a tlc site that didn't allow me to vote so I assume voting is over. Did you make it into the show?
oh my gosh..ITS BEAUTIFUL!!! well done!
Beautifully done... I'm not a fan of using PVC for food, But I can get over that. Great work.
Wow, that is just amazing!
Absolutely Excellent. You really have a gift and talent. I wish you good fortune and a bountiful business venture. It is nice to see your passion in the art you have created in a simple form such as a cake, also thanks for the repeatable instructions.... <br>Michael
Wow, I'm really glad I clicked on this now. It's truly incredible! I dot think you mentioned this but how long would you say it took to create this cake?
This is stunning!! You got my vote!
About This Instructable
51,390views
115favorites
License:
Bio: Hi my name is Liz! I own Artisan Cake Company in Portland Oregon. I make 3D sculpted cakes and lots of toppers on a daily ... More »
More by lizzomarek:How to Make Marshmallow Fondant How I made my Threadcakes "Hooded" 3D cake Edible Angry Birds King Pig Topper
Add instructable to:
