3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How I use the Sun to Cool my House.
This instructable will show you how I converted a 240 volt rooftop Evaporative air conditioner to a Mobile unit run on my DIY 12 volt solar setup.
My setup supports the 2 most important things in the house.
The 12 volt Beer fridge and the Air Conditioner.
Without either of these the summers here would be unbearable.
There is also something quite satisfying about sitting in a cool house sipping icy cold beer on a stinking hot day knowing the sun has done all the cooling.
Step 1The beginning.
The beginning.
First you need to obtain an old evap air cooler.
I bought mine on ebay for around $200. Winter is the cheapest time to buy one.
A trip to the local rubbish tip netted me an old BBQ on a stand with wheels at one end. I left the rusted out BBQ there and took the stand home.
A wooden pallet went with me.
The Air Cooler then had all the electrics, the huge 240 volt motor (unfortunately not permanent magnet) and the 240 volt pump unceremoniously ripped out (taking up space in my shed now if you want them).
It was then attached to the aforementioned pallet which was screwed to the top of the BBQ stand.
Now it's ready for step 2.
99 comments
1-40 of 99next »
Apr 23, 2012. 10:42 AMIronManMC says:
Chlorine and ammonia? There's a warning on all ammonia containers to AVOID mixing with chlorine. That potentially produces deadly free chlorine gas, and several other deadly toxic poisons, depending on the ratio of bleach to ammonia. This article ought to scare the **** out of you.
http://h2g2.com/dna/h2g2/classic/A795611
Do a search for "ammonia chlorine" and see all the disasters listed. It's scary!
Other than your mention here, there is no other reference to "clormanated". Could you please check with your water supplier and let me/us know? Thanks in advance.
-o-
Evaporative coolers REQUIRE a free flow of air FROM OUTSIDE through the wet pads into the house and out open doors, windows, etc.
Some think this works like a refrigeration type air conditioner (it doesn't) and try to "keep the cool air inside" by closing doors and windows. All this does is make the house HOT and HUMID. To remove heat, you must evaporate water with free flowing air.
When you sweat, a fan blowing lots of air across your wet skin and wet clothing cools you. If you wrap up in a plastic rain coat, you will be VERY hot.
I rebuilt an old evap cooler (a large window mount with a 1/2 HP blower motor) and set it up in the back yard for testing. It was well over 110 degrees that day, with very low humidity. It literally cooled the entire back yard.
The less restricted the air flow, the more water it evaporates, and the cooler it gets.
Apr 25, 2011. 7:48 PMjholsinger says:
BEER IS GROSS Thats what I think in the nicest way I can say it of course you may all fill in the blanks with far more Graphic words
Aug 18, 2011. 3:17 PMlove4pds says:
LOL, are you serious?
Aug 11, 2011. 7:32 AMjimvandamme says:
You have never tasted good Belgian beer.
Jun 9, 2011. 7:29 AMThe_3rd says:
So drink lemonade?
Jul 21, 2011. 3:55 AMjose.miole says:
are those "Frogs"? (referring to step 3)
Aug 2, 2010. 8:08 PMFurtherThanTesla says:
Could you please explain exactly how this works? i understand its evaporative cooling with water, but whats the HVAC unit for? and where did you attach the auto raidiator fan? where does the whater evaporate? whats the 12v pump for if you already have water pressure?
Aug 4, 2010. 9:26 AMFurtherThanTesla says:
you didnt really mention wood shavings or the "batts" in your instructable, but thanks a lot for the fast response and info! What i meant with the HVAC was, did you use the radiator pipes or any parts in it? or did you just use the metal shell to house your system? And so what you mean is that - the wood shavings are like sponges that hold the water and give surface area for evaporation. the radiator fan pulls outside air through the wet wood shaving sponges, and becomes colder as the water evaporates, then goes though the fan that pushes it through the duct. - Is that whats going on? oh, and whats holding all the wood shavings? (i live in GA and we have the AC running constantly due to recent heat waves, but are out of money and cant afford cold air anymore - $300 electric bills - ) How much of a temperature difference is there with your system?
Aug 22, 2010. 1:37 AMFarrigga says:
A swamp cooler is cheap to operate, but it will add 50% or more humidity to your home thus increasing mold and mildew problems. Swampers are great in desert areas which can use more humidity, but for Georgia, I believe the problems created with the high humidity would be more costly than paying the electric bill. Plus finding a used swamper in this part of the country is next to impossible. A new unit will cost around $1000 and that figure is from 30 years ago when we lived in the state of Nevada. You can build a small swamp cooler yourself by using a window fan and a wet towel hanging in front of it. Keep the towel moistened at all times and the fan blowing will help to cool the air. This won't add as much moisture to already moist air, but it will also not cool the air as quickly. My suggestion to you is to buy a single small window unit air conditioner, 5,000 btu and cool only one room. That alone should reduce the cooling expense and you will have one comfortable room in your home.
Jul 13, 2011. 2:49 PMjunkerjp says:
Hey Tesla,
Rather than trying to put together an entirely new system for cooling, maybe just add to the system you already have in place. Although, I know its no-where near as rewarding, it may be more economical: Perhaps more insulation above the the ceiling or better seals for the windows/doors/skylights etc. Also consider exterior shades or reflective tints for the windows. You would be surprised to find how much energy is wasted by not containing it. Installing an automated thermostat could also save you money; they are very easy to install, I would bet there are a few Instructables for them.
That being said, changing the entire system is very enticing. You could always start planning for a geothermal, swamp cooling, or other type of cooling system for when your current air conditioner breaks down.
Jul 13, 2011. 6:50 AMkooljon says:
Interesting idea, I must admit.
Jun 10, 2011. 9:52 PMfuzvulf says:
To each his own on what they drink, nice "able".
There is a version of this which uses one more step that doesn't send moist air through your house. It sprays the water over the inward facing slats and then pumps it from the catch pan at the bottom through a heat exchanger through which air that is already in your house is circulated and blown back inside so that you don't have to cool hot outside air. moisture is in fact removed from the air in the house condensing on the cooler surface of the heat exchanger. This moisture (if any) is then routed to the catch pan reducing slightly the demand on municipal water. From the heat exchanger the water then flows to the spray nozzles over the inward facing slats of the enclosure and the process starts over again. everything else is the same as your setup, although using solar to run it is ingenious. Great Job!
Apr 20, 2011. 9:01 PMlabtecmike says:
Swamp coolers are terrible for high humidity climates. No matter how much air flow you have it won't cool your home enough to make it worth your while. The rising humidity level will only make it unbearable.
Jun 17, 2009. 10:42 AMcampingisgood says:
This looks very interesting, but I don't understand how it cools. Thanks
Nov 3, 2010. 10:44 AMtbone56 says:
Thanks for making this instructable.
It is a brilliant idea!
However, here in East Texas, we have pretty high humidity and the house would get 'wet' from using an evaporative cooler. In west Texas they are everywhere.
So, as an alternative, could this be used to cool the attic area of the house? Would this save enough on the main A/C unit to be worthwhile? Would it cause too much moisture in the attic?
Do you know where I might find the answer to these questions?
Thanks.
Feb 24, 2011. 3:54 PMMTJimL says:
Great 'able. Just a thought about air flow through a house in East Texas. A powerful ceiling exhaust fan is a godsend, when taking air in from the shady side of the house and blowing it out through the attic. Just that will make a sweltering afternoon feel tolerable. If the incoming air is routed through a swamp cooler, so much the better. If the house is air-tight, the ceiling fan should provide all the air exchange you need, and prevent moisture buildup in the house and attic.
Nov 3, 2010. 1:47 PMtbone56 says:
Thanks Rob. Yes good tip on the airflow.
Yes, our house has insulation between the ceiling and attic. However, all the central A/C ducting runs through the attic space. My feeling is that if the attic space had cool air coming in at the eaves and the hot air drafting out at the roof peaks, then this may lower the attic temperature, and then reduce the heating of the cool air ducts.
When I first began thinking of making solar panels to generate electricity, I was kind of at a loss for how to use this energy in a way that would help reduce our energy costs rather than just give me more ways to use free energy.
After reading your instructables I think that I might be able to use your idea to reduce our energy costs without the issues of tapping into the house electrical system.
Thanks. You have given me some good inspiration here.
May 28, 2011. 2:10 PMjsadler1 says:
Normally your air ducts are insulated to keep attic air from warming them.
Evaporative cooling has severe limits in humid areas. For example large buildings use chillers with water towers. The water towers use high horsepower fans and pumps to drop the water down through the towers. The idea being that evaporation will cool the water that makes it to the floor of the tower. That turns 95 degree air into 85 degree water. That water chills the hot side of a huge compressor so that large amounts of freon are not pumped through the building. The reason being that people could drown in freon in those quantities. The cold side of the freon loop is used to chill water down to about 52F and that cold water is pumped to coils in various rooms where fans behind the coils push air through them to cool the rooms.
That is the only use of evaporative cooling in humid areas that bears fruit at all. It is expensive beyond imagination and the water bills alone would break you.
The best bet is to get a central AC unit and replace it more often than you usually do. The rotary compressors are a good bet these days and a great energy rating is vital. The days of keeping an AC for 15 years are not with us anymore and decent AC units are expensive.
Aug 4, 2011. 5:46 PMlloydrmc says:
Very cool (pun intended)!
Nov 3, 2010. 6:26 PMtbone56 says:
Congratulations!
Nothing like a good idea put into action paying off bigtime!
Glad to hear that bit of news!
Tom
Jun 19, 2009. 5:55 PMcampingisgood says:
Hi, Thanks for the info. The design is simple, yet brilliant.
Sep 7, 2010. 6:18 AMShiftlock says:
How well does a system like this work? By how many degrees will it lower the temperature? For example, if it's 100F outside, what temperature will this system keep your home?
Oct 30, 2010. 1:35 AMde Oliveira says:
Hi Rob;
I have an idea but don't know if it works well (or if really works).
Remove the hot section of your evap. Make a larger, without radiator, with only copper pipe (it needs a long and thin pipe). Take the thin pipe on the roof for the sun to warm it, connecting the pipe coming from the roof to the other side of evap system again. Fill the system with gas normally.
The pipe takes the sunlight and will be warmer. This heat will increase the pressure inside roof pipe and your evaporator will do the rest like using electricity to compress the gas in the pipeline. You just change the place and size of the radiator.
The system remains the same, except that it is not necessary to turn on the compressor, only the fan (there is a refrigerator that runs on kerosene or gas flame - this would be the mode of operation of your system, however, bigger).
Well, you may need to call a professional to do the calculations on the amount of gas, change valves or something more, but it can work. You also need to paint the roof pipe black to absorb more sunlight. I think that more pipe on the roof, more sunlight taken and more heat absorbed in evaporator side.
If it works, will be for a lifetime without power consuption, except the fan electric motor.
You can see something here (in portuguese)
http://www.depijama.com/verdes/uma-geladeira-movida-a-fogo/
and translate here: www.tradukka.com
Watch here:
http://www.youtube.com/watch?v=HSdXqmnNCp0
Search by Adam Grosser - Stanford - fire refrigerator - new gas. It may be your solution.
Sep 20, 2010. 4:49 AMShiftlock says:
Right, I understand the way to use this kind of system is to create an air flow through the area you're cooling. This seems odd to most Americans, because we don't have that kind of cooling system here. Everyone here has power-hogging compressor A/C systems that work like big refrigerators. Most Americans make their large homes 20C inside 24 hours/day, no matter what the outside temperature is. Even if it's over 40C outside. It uses an incredible amount of power. Just another part the wasteful power-hungry society here that had better change if we're to keep this planet habitable. Your comment about going outside to feel the relative coolness of the inside was a perfect example of something most Americans would never consider doing. What, take all that effort to walk outside? We're too lazy. Just pump the A/C down a little more. Really sad.
Sep 30, 2010. 3:26 AMTroy_187 says:
i put a big block of ice in my swamp cooler on really hot days. it works great
Sep 19, 2010. 6:53 AMPedros2 says:
There are no problems with swampies here in aussy, what mold we have run one for 30 or more years and think they are great, and thats a great idea to run off 12 volt thanks for the ideas, cheers
Sep 7, 2010. 12:46 AMthrowedoff says:
nadeem5476, there are no coils to this system. It is an open system with water as the coolant. The water is pumped to the top of the swamp cooler where it is trickled down the sides into an absorbant media. Air that is pulled into the vented sides through the media cause the water to evaporate thus cooling the air. Swamp coolers or evaporative coolers work very well in dry climates and do not pose any health problems in a properly maintained system. These systems are very poplular because they have less power requirements than refrigerated systems, and they are used world wide.
Sep 12, 2010. 4:28 PMmenahunie says:
True. My parent and grandparents were raised in the desert around Palm Springs Calif.
You will see over 90% of houses with swamp coolers.
Most if not all commercial bldgs. use this type of system on a much larger scale to cool the bldg. They would cool down a chill water loop to around 50 degrees and pump it in insalated pipes to evaporator where air would be blowing through them into the bldgs. rooms.
Sep 12, 2010. 4:21 AMt.hecking says:
Nicely done instructable. Perhaps you could eliminate the water pump altogether by dripping or spraying city water directly on the pads?
Using a filter could eliminate chlorine and other nasty stuff from entering your house. Insulating the feed water pipes will keep the water cool.
Sep 10, 2010. 7:31 PMihwild says:
For those concerned about humidity what about running either the cooled air or the to be cooled air through something like an intercooler (explanation at bottom)similar to a turbo system on a vehicle. Then have the other air running over the fins into the house or through the intercooler into the house. I'm not sure which one would cool the house air better.
Intercoolers: Basically they are a heater exchanger for air to air or in some applications water to air (when the turbo or blower produces boost it also heats the air, the intercooler allows a chance for that heat to be removed by either air over the fins or water absorbing the heat.) They are also designed to not restrict airflow much unlike trying to force air through a car radiator where the liquid normally would be.
Just a thought. I like the idea though.
May 27, 2009. 9:13 AMadrian.ccs says:
Hi Rob Patto, Where do you include the part that power up the whole system?
1-40 of 99next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:Rob Patterson
I'm just an ordinary bloke with an inquiring mind. I love to help people and find "Instructables" a terrific place to do that.
