3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How Not to Lose Respect on the Internet
Step 2Don't Misuse the Apostrophe
Aside from misuse of capital letters, or more often the lack of any capital letters at all, the other common mistake that I see all over the internet is the abuse of the apostrophe. In English, the apostrophe is used to indicate the omission of letters and to indicate the possessiveness of many pronouns and all nouns. So, let's break that down:
Apostrophes are used in contractions such as don't, you're, it's, won't, can't, and many others. If you're going to use an apostrophe in this manner, it's going to be replacing one or more letters. If I were to rewrite that last sentence without using any contractions, it would look like this: "If you are going to use an apostrophe in this manner, it is going to be replacing one or more letters." In general, avoid using contractions and abbreviations, as it makes your writing look better and eliminates a common source of errors. To put it another way, don't use contractions.
Apostrophes are also used to indicate possessiveness. If you want to indicate that something belongs to someone, use an apostrophe followed by an "s" at the end of the noun or pronoun (note: not all pronouns use 's to indicate possessiveness). If you simply put an "s" without an apostrophe in hopes that you will indicate possessiveness, you will fail in most cases. An "s" alone at the end of a noun that does not normally end with an "s" indicates plurality. The fragment "my fathers house" has a much different meaning than "my father's house." In cases where a noun already ends in an "s," there are two schools of thought as to how to indicate possessiveness. The first method, which is favored when referring to the possessiveness of proper names is to tack on the "'s" as usual. An example of this can be seen when you want to refer to H. G. Wells's short story "The Country of the Blind." The second method is to just put an apostrophe on the end of the noun. This method can be seen when you want to refer to the blind citizens' treatment of Nunez in "The Country of the Blind."
A few things to note:
--In British English, the apostrophe or "single quote" is used to indicate speech in writing rather than the "double quote" used in American English.
--If you happen to be quoting something that has a quotation in it, the single quote is used to indicate the quotation within your quotation.
--"It's" means "it is," "its" is the non-gendered third-person possessive pronoun.
9 comments
Jul 29, 2009. 8:55 PMRotten194 says:
If a person's name ends with "s" and you wish to show possession, there is no "s" after the apostrophe. E.G.,if the person is named Bobs, it would be Bobs' paper, not Bobs's paper. Sorry, that just drives me CRAZY on the internet.
Dec 15, 2009. 6:21 PMVinnyVanGogh says:
 In other words one would say "Chris' paper..." instead of "Chris's paper..."??
Jul 29, 2009. 9:50 PMcasey321b says:
You do that...
Jun 24, 2008. 2:13 AMHamatoKameko says:
"To put it another way, don't use contractions." There is a distinct irony here. ;) And you know, even though I've always had a talent for spelling and grammar, to this day (I'm 24), I have trouble with "it's" and "its." I know the rule, but when I'm writing/typing, I always use the wrong one.
Oct 31, 2009. 4:07 PMHycro says:
Yeah, I do the same from time to time, though I usually manage to catch it and correct it. Half of what I type is probably riddled with grammatical errors, but then again, often the reply I receive is worse...
May 19, 2008. 6:35 AMTURNERO says:
I'm not sure you're right about the "single quote" in British English, I think it's the same as American English. You could very well be right but I'm pretty sure when I was at school they taught us to use "double quotes" for speech.
Oct 31, 2009. 4:01 PMHycro says:
In Canadian English, we were always taught to use the "double quote" to indicate speech...
May 19, 2008. 3:27 PMross353 says:
its "double quotes " and single for nameing something such as a movie or a play 'The Truman Show'
Jun 4, 2009. 12:30 PMnel_rambling says:
Also, when indicating possession by a group, place the apostrophe after the 's', i.e. 'the ball belonging to the boys' becomes 'the boys' ball'. As a native English speaker, I've found that single quotes are increasingly used, whilst italics denote titles (of books, for example), although either is acceptable. Speech marks, or double quotes, should, however, never be used for titles of things.
Jun 21, 2008. 11:25 AMbranchporter says:
Sometimes this is a problem for me. If an embedded quote or title comes at the end of another quote, should you end the sentence with a "single quote" followed by a "double quote", as in this example? Mary said "John read a passage from 'Gone with the Wind' ".
May 25, 2008. 8:20 PMA good name says:
wha't a're yo'u talk'ing a'bout
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:TheMadTinker(The Real Me)
I'm a top-hatted, kilted, bike mechanic and author with a fondness for silly things and delicious food. Holler at my Philly folks!
