Introduction: How to Annoy the Heck Out of SomeONe Younger Then You
How To Create Annoying Sound Only Someone Younger Then You Can Hear
Step 1: Not Hard at All!
*Updated! 02/05/08 New version of the program has come out! Use step 4 and ignore 2! Ill try to move them later but I get A Java error when I try to now*
The Concept is simple, as you get older, the less higher frequencies you can hear. But when you were younger you could here much higher frequencies then you can hear as you get older. So using a freeware program NCH Tone/Waveform Generator,
http://www.world-voices.com/software/nchtone.html ,
you can create higher frequencies that only younger people can hear.
Step 2: *Old Version*
Like I said, this is the old version, Ignore it unless you have to use this version!
Using this program is strangly easy. First, find a frequency thats just over your hearing range. You can do this by clicking the up and down buttons next to the HZ sign, then clicking the start button. Once you found a frequency you can barrely hear, click the save as button and save it as whaterver you want.
Step 3: Start Annoying!
Once you are done put it into itunes, click repeat one, turn your speakers up and watch your younger victom go crazy!
PS Some Speakers can't haandle the higher freqincies, smaller is better!
Step 4: *Updated for New Program!*
After looking into so posts that the software has been changed, I updated the instructible. The old version is set as the last "page" if you still have the old version. The new version is actually easier to use so I highly recommend you get it!
1)When you open up the program you will see this screen, double click the "Sine One Frequency"
2)It will pop up with a new box that says "1000 HZ" Chane that to anything you want (I don't recommend anything above 20000)
3)Play it to test, Save it, And viola! A beautify created anoy-a-tron!
