Remove these ads by
Signing UpStep 1: Procuring Parts
1. Processor (CPU)
2. Computer Case
3. Optical Drive (DVD RW and SATA capable)
4. Memory (RAM)
5. Power Supply
6. SATA Cables
7. Motherboard (SATA Capable)
8. Processor Fan
9. Case Fan
10. Hard Drive (SATA Capable)
11. Assortment of case and drive screws (Not Pictured)
12. Flowers (necessary if you are invading the space of your significant other)
Most, if not all of these parts can be bought together in what is known as a “barebones kit”. In this instance, the case, motherboard, cpu, hard drive, and memory were bought together from tigerdirect.com as a barebones kit for around $200. The DVD drive and cables were purchased from newegg.com for less than $30 before shipping. There is an obvious financial advantage to buying parts bundled together, but less obvious is the benefit you will realize from the amount of time you save trying to research parts compatibility.
Caution: Double check the manufacturer’s specifications on all items before you purchase them. Kits are supposed to contain compatible parts, but mistakes can happen.
Visit Our Store »
Go Pro Today »
BTW it's facing the wrong way. the label is supposed to face outwards, which is also the way the air should flow. you wanna suck the hot air out rather than sucking more air in. It also makes less noise ;D
