3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Assemble A Basic Desktop PC
Step 11Install The CPU Fan
Install The CPU Fan
The CPU fan is really a combination of a heat sink and fan together. The unit draws heat away from the CPU . To install the fan:
  1. Place thermal compound to the CPU following the instructions provided with the compound.
  2. Set the fan assembly on the CPU with mounting tabs aligned.
  3. Pull the locking rod down on the fan assembly to lock into place.
  4. Connect the fan assembly's power connector to the motherboard. Consult the manual to determine proper placement.
Caution: Failure to apply thermal compound will result in insufficient cooling and will cause damage to the CPU and/or motherboard.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jimirayblues
