3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Assemble A Basic Desktop PC
Step 12Install Case Fan
Install Case Fan
The case fan is usually installed on the back panel of the case. If the fan mount is not obvious consult the case documentation. To mount the fan:
  1. Align the mounting holes by holding the fan to the mounting pad on the inside of the case as shown in figure 25. The fan needs to be mounted so that it blows air out of the case.
  2. Insert the screws from the outside of the case and tighten.
2 comments
Feb 10, 2011. 12:30 AMJay Spannerz says:
Agreed (I clean mine with a simple paintbrush)
BTW it's facing the wrong way. the label is supposed to face outwards, which is also the way the air should flow. you wanna suck the hot air out rather than sucking more air in. It also makes less noise ;D
Aug 2, 2010. 12:56 AMMiles Tails Prower says:
Man, that fan is DUSTY! Clean it before you install it, man.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jimirayblues
