The hard drive is the device that stores all of your data. It is 3.5" wide and needs to be mounted so that you can gain access to the cable connections on the back (figure 16). If that is not possible you may need to connect cables before you install the drive. To mount the drive:
Find a 3.5" drive bay to install the drive in. If you have trouble finding a place to mount the drive consult your case documentation for suggestions.
Slide the drive into place until the screw holes on the sides are lined up with the holes in the case.
Install the screws.
