Step 4The Cross-Brace
Later on, we found that this really didn't work, and ended breaking a really nice fiberglass pole because of it (and the insane momentum it had).
If you want to go true catapult, the cross-brace is essential, but I highly advise against it.
If you don't want a cross-brace, you'll have to get two more u-bolts and bolt them to the top of the posts so that they face eachother. Otherwise, follow the instructions below.
To install a cross-brace, first pre-drill four holes in that leftover 3' 4x4 that you cut earlier (two on each side), after clamping it to the top of the two 4x4 posts we put up in the last step. The cross-brace's top should be flush with the top of the two posts, and should be closer to the shorter side of the base of the frame.
Now, start screwing your lag bolts into the cross-brace piece. You can take it down from the posts now if it makes it any easier. Keep turning until the little pointy part sticks out of the other end of the wood, then re-clamp it and finish up. Turning lag bolts in 4x4's is pretty annoying, isn't it?
Drill two huge (but not too big... say 1.5") holes into the cross-brace on both sides. This is there the surgical tubing will go, so try and make it nice and smooth. Our tubing ripped a few times because the holes had sharp wood daggers eating the tubing. It's pretty scary when one of those snaps at full tension.
Also, on one side, install the other U-bolt, facing inwards, through one of the posts - this will be a tie-off point.
Add a ton of padding to the cross brace - you'll need this if you don't want the catapult/arm to break.
Add Comment
