How To Build A Finch Bird Feeder
I was in a bird store to buy a finch feeder. I saw one for about $20, but immediately thought, 'I can make this, and probably for less.'
So I tried, and sure enough, for a cost of about $5 and 20 minutes work, I made one that looks better than the 'professional' model. Here's how I did it.
Step 1Buy The Parts
Buy The Parts
It just so happened that next door was a TAP Plastics store. In there I found something called a Tube-Pak. It is a clear plastic tube with a red cap on either end. I chose one 18" long and 2" in diameter (cost: $3.50). Then I found some cool 1/4" colored acrylic rods ($3.45). I chose purple. Now it's time to build.
9 comments
Jun 25, 2009. 11:45 AMfw2000 says:
thistle seed is very tiny and the finch beak is very thin. try using 1/16" bit and make slots 1/4" long running top to bottom. Now for the show - the finch is the only bird known to hang upside down and eat. Make your slots under the perch instead of above. No other birds will eat at this feeder.and it is awesome to watch them land, swing over, and eat.
Feb 25, 2009. 9:55 AMconradhop says:
I just discovered something about this feeder that is different from the store bought ones. The store bought ones get filled from the top. So, the seed at the bottom just sits there and gets old and soggy. I fill this feeder from the BOTTOM so the oldest seed is now at the top and always gets eaten first. I never have old seed to clean out of the feeder. Very cool.
Dec 2, 2008. 8:20 AMcanida says:
Looks great! I had no idea those feeders were so easy. Is there a specific kind of seed that should be used with this type of feeder, and do you need to change hole size for other seeds? We're big fans of TAP Plastics - you're our source for most of the plastic we use on internal projects! Thanks for posting.
Jan 31, 2009. 3:07 AMAndyGadget says:
A few of weeks ago I modified a normal feeder for nyjer seed and put it up near my other bird feeders and watched hopefully for a feeding visit from the goldfinches which we've seen passing through. Nothing, then I remembered something about birds responding to the colour red. I outlined the main feeding slot and smaller holes with bright red indelible pen and a couple of hours later a goldfinch stopped by and gorged himself for ten minutes. Half an hour later and he must have told his mates because we had a charm of 8 goldfinches around the feeder. I haven't counted 8 since, but there are usually some around in ones and twos. Gorgeous little birds, but very aggressive in their feeding. They will see off any other nearby bird.
Jan 17, 2009. 6:34 AMnjdjs says:
Only thing for me is I live where its hot and the sun beats on the feeder so I need one that the plastic has UV in it so the sun don't kill it. But for the shade areas this is a great idea I wish I had some shade to put some in I would make a bunch.
Jan 22, 2009. 8:05 AMconradhop says:
Use Acrylic tube for the feeder and it will be totally UV resistant. Acrylic lasts forever outdoors. The bird perches are already acrylic, so they are fine.
Dec 2, 2008. 12:27 PMAndyGadget says:
In the UK, you'll attract goldfinches with nyjer seed - they love it. BTW, the collective noun for goldfinches is a 'charm'.
Dec 2, 2008. 8:12 AMconradhop says:
You're right. It took me less than 1/2 hour to make, and it works!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
32
Author:tap guy(TAP Plastics)
TAP Plastics has been providing customers with unique fiberglass, plastic and related products since 1952. We specialize in fiberglass resins and fabrics for fiberglass repair, plastic containers, and...
more »
