How to Build a Robot That Pulls 5 Pounds
Published
Introduction: How to Build a Robot That Pulls 5 Pounds
Agnes Koroma, Areej Ali, Safiyya Qadir
Step 1: Control Relocation
Move the control and place it flat onto the robot.
Step 2: Battery
Tape the battery on top of the control.
Step 3: Wheels
use the 100mm wheel to add on each side
Step 4: Wheels
Place the 100mm wheel on each side
Step 5: Angle Bars
in order to extend the front of the robot you need four angle bars
Step 6: Extension of the Angle Bars
extend the angle bars on each side in the front of the robot in order to add an extra 100mm wheel then close it with another angle bar in front of the wheel.
Step 7: Program
download a go forward progrm onto the robot
Step 8: Sled
This will be used in step 6
Step 9: Weight
add 2 2.5 weights on the back of the sled
Step 10: Sled Attachment
Then add a sled on the back of the robot.
Step 11: Materials
1. 3 100mm wheels
2. 3 10 hole angle bars
3. 4 chassity rails
4. vex controller
5. battery
6. 2 motors
7. keps nuts
8. 8-32 screws
9. 2 60 tooth gears
10. 2 12 tooth gears
11. collars
12. 1 5 hole angle bar
13. sled
Step 12: Calculation
Robot calculations
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Creative Misuse Contest
    2 Discussions
