3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Build A Solar Panel
Step 2Assembling The Solar Cells
Next, while my first coat was drying, I started to work on assembling the solar cells. The best way to learn how to assemble the solar cells would be to simply watch the video. A quick overview of it is, the bottom of the solar cell is the positive side, and the top of solar cell is the negative side. I wanted to connect the solar cells in series, with a total of 36 solar cells, which will give me 63 watts. I used tabbing wire with a soldering iron to connect the solar cells together. For my panel I had 3 strings of solar cells. To connect those strings of solar cells, I used what is called a bus wire. The bus wire goes at the end of the strings to create one long string, however, curled up in a way like a snake. Again, for step 2, I recommend you watch the full video (Part 3) to understand how to work with the solar cells and how to check the voltage/current.
6 comments
Jul 16, 2010. 4:05 AMjhunmar100 says:
where can i get solar cells ????? pls reply i need the answer please:(
Jul 20, 2010. 2:02 PMairsofter1 says:
You can get them from ebay. Just type in solar cells and you will be on your way.
Aug 26, 2010. 6:38 PMjhunmar100 says:
thanx a lot dude...:)
Jul 16, 2010. 1:42 PMhow to make a solar panel says:
They are easy to find and buy, I have had great success building my own solar panels for my house, there is so much great info on this site for you to apply.
Oct 8, 2009. 7:51 PMBig W says:
could i use just straight soldering wire with no flux?
Oct 23, 2009. 12:27 PMairecrist says:
there is solder wire you can get with flux in it though idk how well it actually works or where to get it, how much it is.
Oct 9, 2009. 3:51 AMBig W says:
ok. thanx. one more thing, how do you workout the Volts to watts, and watts to kilowatts, for running fridges, freezers and other stuff.
Oct 10, 2009. 8:42 AMairsofter1 says:
 To figure out watts, You multiply volts times amps( 3.5 amps for a 3 by 6 inch cell). 1000 watts equals 1 kilowatt.
Aug 13, 2009. 12:39 PMmark28 says:
hi, where did you get the littles solar cells or you made them?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
97
Author:hastyhost(Robert Smith)
Robert Smith discovered the wonders of online content at an early age. He started out while in middle school using free web services to create an online forum that served as a central location for all...
more »
